I guess I've been around long enough and done enough to earn myself a build thread :bigthumb:
Picked her up in October 2015 with 105K miles on it. '07 Voodoo w/ Diff Lok (UPDATE: 205K miles Sept. 2023)
Suspension/wheels:
-255/80R17 mix-n-match. lol
-Stock wheels
-SpiderTrax 1.25" wheel spacers
-BMC
-Wheelers Offroad bumpstops
Front:
-Light Racing UCA's W/ V2.0 sealed joints
-Walker Evan's 2.5 non-resi
-Eibach Shock Sox
-Total Chaos spindle gussets
-GX470 Big Brake kit conversion
-No sway bar
Rear:
-MT long travel springs
-Icon VS 2.0 shocks
-Resz Fab upper & lower links (Duroflex, now defunct company)
-Eimkeith weld-on PCK
-No sway bar
Armor:
-RCI steel skids - engine, trans & transfer case
-BudBuilt fuel tank skid Custom skid on LRA tank
-PureFJ sliders (refinished myltiple times & going strong)
-Lzalusky lower link cups
-Aluminum front LCA skids
Electronic:
-Lifetime LED headlights (Now defunct... not very "lifetime")
-Icom 2730 (Ham & GMRS)
-Kicker 8" shallow sub in OEM housing
-Pioneer bluetooth head unit w/ backup cam
-Diode Dynamics everything
-Hella Supertones
-Ultragauge MX-1.3
-LUX microMAX rock lights (a more mature removed them, rock lights are kinda silly...)
-Baja Designs Squadron Pro's on DBC cowl mounts
-Victron SmartSolar MPPT 75/15
-175W Renogy solar panel
Recovery:
-Lucrum hidden winch bumper
-Smittybilt XRC Comp 9.5 winch
-Iconic_ rear recovery shackle mounts
Performance:
-AFE cold air intake
-Stainless steel extended brake lines all around
-Marlin Taco Box dual transfer case (Install thread here)
-Marlin 4.7:1 competition gear set (23 spline)
-GX470 front & rear 3.91 differentials (to eliminate the problematic ADD actuator)
-Transmission cooler
-Poly motor mounts
-Poly transmission mounts (Custom Cross-member)
-CSF high flow all-aluminum radiator
-URD timing gears
-URD high pressure fuel pump w/ external filter
-NST lightweight pulleys and harmonic balancer
Exterior:
-TT bumper wings
-TT door handles
-Rad Rubber Designs splash guards
-Warrior full flat rack
-AVS window vents
-Iconic_ Rear WIY high clearance bumper (In the works!)
Interior:
-LED dome lights
-08+ side visors
-GZilla mini Mag mounts
-DIY heated seats
-Lighted door handles & pockets
-Clazzio napa leather seat covers
-8 Ball style shifter knobs
-5lb Purple K "BC" fire extinguisher on a Refined Cycle seat mount.
Other goodies:
-Bandi 1/2" body lift
-Disabled DRL's
-Custom drawer system w/ slide-out
-Fumoto oil valve
-Tuffy flip-up license plate winch mount
-Adventure Trail Gear G.A.R.B.
-Whynter 45 quart fridge/freezer.
-Long Range America tank 30 gallon (Modified down to 26 gallon...)
-CVT St. Helens hard shell (Now on custom M416 offroad trailer)
-Custom built M416 offroad trailer
Mods still in the box...
-N/A
First wheeling trip out. Found the FJ's cousin (with a 454 in it!)
The first round of suspension goodies! MetalTech Long Travel rear, and TJM lift struts with 650lb Eibach springs.
The first round of 285's (picked them up cheap used). Loved the Duratracs, but god they're expensive!
Lifetime LED headlight(s) installed. What a difference! I'd venture to guess 20-25% brighter than OEM.
New shoes! 285 kanati mud hogs. Dirt cheap (~$180/tire) and wicked tread, give them 7.5/10 after 5 months of use and several major snow storms.
The second round of front suspension goodies. Walker Evan's 2.5 coilovers (AllPro- discontinued) with 650lb springs and Light Racing adjustable control arms (set to +2.0°). Ditched the sway bars. Also added coil wraps for the winter, I hate NE salt...
More to come!
Suspension/wheels:
-Stock wheels
-BMC
Front:
-Eibach Shock Sox
-No sway bar
Rear:
-Icon VS 2.0 shocks
-No sway bar
Armor:
Electronic:
-Hella Supertones
-Ultragauge MX-1.3
Recovery:
Performance:
-Poly motor mounts
-URD timing gears
Exterior:
-TT bumper wings
-TT door handles
-AVS window vents
Interior:
-LED dome lights
-08+ side visors
-DIY heated seats
Other goodies:
-Disabled DRL's
-Fumoto oil valve
-N/A
