Old 05-16-2007, 10:12 PM   #101
LAB 601's Avatar
Member Number: 1582
Send a message via Skype™ to LAB 601
Re: A few mods 7-25-06
corey, thanks for the write up on the rear aux dc ports, i found the radioshack outlets and an inexpensive fuse block that i'm mounting above my inverter port- thanks again-easy to do, gonna run my new engel from it
thanks
dave
David C. Ballard
President & Creative Director | LAB 601, Inc.
LAB 601 Digital Post
404.876.4601
www.lab601.com
LAB 601 is offline
Old 05-25-2007, 10:57 AM   #102
Corey's Avatar
Member Number: 2902
Re: Corey's FJ with a few mods!
You are welcome Dave.
Show us some pictures after you get yours done.
Corey is offline
Old 05-26-2007, 05:43 PM   #103
LAB 601's Avatar
Member Number: 1582
rear all time hot dc install
here it is, i ran the hot to the back through a small hole in the passenger side engine compartlment top corner that gets to the boot in the door jam, seemed easy to get too, then ran it in the door boards to the back. put a fuse block back there where the outlets are.
dave
David C. Ballard
404.876.4601
www.lab601.com
LAB 601 is offline
Old 05-26-2007, 05:53 PM   #104
Corey's Avatar
Member Number: 2902
Looks good!
Which box is that back there, it is the new Tuffy one, or another one?
Corey is offline
Old 05-26-2007, 06:21 PM   #105
LAB 601's Avatar
Member Number: 1582
Corey previously said: View Post
Looks good!
its the tuffy rear storage box, non fj, it seemed too big for back there. it is 7inch interiour height and 8 or so total. shimmed to the driver side so there is gap for the electrical on the passenger side still.
i find that for the stuff i tote, this box is perfect. only thing, i wish tuffy ran stiffening supports along the top
dave
David C. Ballard
404.876.4601
www.lab601.com
LAB 601 is offline
Old 06-03-2007, 09:23 AM   #106
CactusJK's Avatar
Member Number: 1157
Re: Blue Sea aux. fusebox & twin 12v outlets installed 4-28-2007
Using the same fusebox, can you use 10 gauge vice 6 gauge for the power and ground wires? As of now I have and ARB refrigerator, 12 volt rear outlet, and a Garmin GPS power cord wired into the box. I plan on only running small loads. Also, if the ARB draws 2.7 amps max is a single 18 gauge line from the fusebox okay for runnning both of the rear outlets?
Thanks to member KD7NAC_07FJ (Wayne) for coming down to my home today to help on this project.
Take one Blue Sea 6 gang fusebox
BLUE SEA 5025 ST BLADE FUSE BL6 CIRCUIT W/NEG BUS - 5025
Tie it in with 6 gauge wire from the battery to it, and run 18-Gauge Red & Black 2-Conductor back to twin 12v outlets
RadioShack.com - Power & Batteries: Adapters: DC (12V/Car) adapters: 12VDC Car Power Accessory Outlet
and you have a recipe for adding several circuits easily from inside the right front kick panel.
I will utilize one of the 12v outlets in the back to power my new ARB fridge.
All connections are soldered and have shrink tubing added to them.
Wayne used a small butane torch to solder the connections with.
A lot of perfection went into this.
I would have crimped the ends and called it a day, but Wayne is very experienced at this and went all the way with the solder and shrink tubing, very professional.
The first 2 pictures show a few things torn apart.
You have to remove the floors threshold by grasping it and pulling straight up.
Once removed you can easily take off the passenger side kick panel with a plastic thumbscrew which is all the way forward.
Wayne ended up taking the battery out to gain better access to the wires presently on the battery.
We moved the CB power wire off of the battery and it is wired inside the cabin now with the new fusebox.
You can see in picture 4 a slit inside the read circle which was already there from running the CB wire to the battery.
Pictures 5 and 6 show the panel you remove by inserting a small flat tipped screw driver and prying it outwards.
Picture 5 still has the yellow sticker on it with info on the 10v converter outlet.
You remove the yellow tape and use a hole saw sized at 1 3/32" and drill 2 holes.
You can also use a knife and make a small incision since the 12v plug has a "key" on it to hold it tight so it will not spin on you.
Picture 6 shows the twin 12v outlets in place.
Picture 7 shows the new Blue Sea box mounted in place with white zipties (no need to screw this unit down) and the 18-Gauge Red & Black 2-Conductor wire attached to it.
This fusebox also utilizes a ground, so you can attach the black ground wire to one of the three screws on top, and attach the red power wire to one of the three screws below.
This box is much nicer than the cheap one I used on the 4Runner long ago.
It did not have a grounding circuit.
Picture 8 shows the 6 gauge wire inside of the black wire loom going down to the slit in the firewall.
It is all tired in with zipties to the factory harnesses running along the firewall.
And finally picture 9 shows the twin 12v outlets in place.
After the battery was put back in place and all the wires were reattached, I carried out the ARB fridge and set it on the ground and plugged it into one of the 12v outlets.
I reached down and rotated the switch and the green light came on the fridge and the sweet sound of a fridge coming to life was like music to my ears
From what I have read, the fridge only draws a maximum of 2.7 amps when set to the highest setting to freeze.
When set to just keep food at the safe temperature to prevent spoilage, it draws much less and can go for 3 days without wearing your battery down.
This project turned out great.
I am pretty decent at wiring projects, and Wayne is much more experienced at what we tackled today.
It turned out really good.
I think I will have to hit him up again when it comes time to do the dual battery setup.
He has that setup and it looks fantastic.
Frozen ice cream bars will be on the menu for this summers runs!
I look forward to getting lots of use from the new ARB fridge and the newly added fusebox and twin 12v outlets back there.
CactusJK is offline
Old 07-17-2007, 12:44 PM   #107
CactusJK's Avatar
Member Number: 1157
Re: Panavice dash mount/grip installed 12-13-2006
Corey - did you run a power cable to your Garmin? I have the same mount for my Garmin 60CSX and have the power cable plugged into my Blue Sea fuse box mounted where you have it. The question is how best to route the cable to the PanaVise? Right now it is in the glove compartment and can be fed out of the compartment with the door shut. Is there a "cleaner" way without drilling?
You can use this mount for your iPod, cell phone, or a GPS.
I already have a very nice iPod mount, but it is kind of in the way of my A Trac and E Locker buttons.
I may move the iPod up above now, or use this for a GPS mount depending if I can get a signal there or not.
Here is the thread that turned me on to it.
Very easy to install.
1. Take off the plastic wing with one screw at the bottom of your stereo dash and pull it off.
2. Take the small metal piece and put it under the screw by the stereo, and mount it.
3. Put the dash plastic wing back on again.
4. Use the two small acorn nuts to put the rest of the Panavice mount to the smaller piece.
5. You can pre-mount the PortaGrip to the backing plate first like I did.
Here are some links:
FJ Cruiser Panavice mount
Model # 751372007
Panavice PortaGrip mount to put your toys in
Mode #l 702 PortaGrip
CactusJK is offline
Old 07-17-2007, 12:56 PM   #108
Corey's Avatar
Member Number: 2902
No, have not ran power for the old yellow Garmin eTrex.
If I get serious enough someday for a new GPS for off road, then I will think about doing that.
Next mods that are coming up will be a 2nd battery box and a snorkel.
Gotta do that latter first though, if I put in a battery box first, I may find out that the snorkel may not fit.
Corey is offline
Old 07-17-2007, 05:38 PM   #109
EDH-FJ's Avatar
Member Number: 4188
I've got the 60CSx and ran power to the regular fuse block and mounted it on the left side of the steering wheel. I wanted it there so when I kill ignition it shuts off GPS after 30 seconds and I don't kill the internal GPS battery... Didn't want to worry about accidently leaving it on. My aux batt has the Blue Sea fuse block on it and powers my ARB Fridge in the back (same setup) and CB.
2007 Sun Fusion 4x4 AT
CQ, Upgrade #2 A-Trac, Diff Lock
Roof Rack, Hitch
MODS:
Goodyear Wranger Silent Armor 275x70x17s
Dual Battery Setup
Locker Hack
All Pro Adjustable Suspension Front/Rear, Rear Springs
All Pro Rock Rails
All Pro Rear Links
All Pro Bandi Mount
Total Chaos UCAs
Budbuilt Skids
Cobra 75WXST CB
Scanguage II
Garmin 60 CSX GPS w/ external ant.
ARB Fridge
ARB Bumper w/ IPF fogs
Warn 9.5XP w/ Winchline Synthetic
PIAA 580 Driving Lighs
EDH-FJ is offline
Old 08-01-2007, 05:28 PM   #110
Corey's Avatar
Member Number: 2902
New tires & wheels installed 7-31-2007
I really dig the stock 17" factory alloys, so much I wanted to buy a 2nd set and move up to a 285x70x17" tires, about the same as a 33" tire.
My current Dick Cepek Mountaincat muds are 265x70x17", and they look great, but a little out of place with the OME 3" lift.
With all of my past vehicles I have owned I have always ran two sets of tires.
One set for fall through spring (winter setup) and the best setup for spring through fall.
I have been wanting to get the same tires in the 285 size, but did not want to pay Toyota $340 a piece for the factory alloys.
Great wheel, only factory wheel I have every truly liked that much on any rig.
A little to steep at that price, although I have a few sources to get some used ones.
At the Greenwater run earlier in July I saw an FJ Cruiser (owned by member noworries) with some nice black wheels that made me again want to think about getting an aftermarket wheel.
With some research and getting a hold of the owner gain, I found out they are the Pro Comp 7089s.
He is running a RevTek 3" lift and 295 size tires with no rubbing, so this tells me that Pro Comp did their math and is overing these with zero offset and able to clear the large calipers of the FJ Cruiser.
I was able to score these wheels for $129 a piece from 4WD Parts who owns Pro Comp wheels/tires.
Les Schwab would have had to buy them for $209 a piece since they are a direct competitor of 4WD Parts Warehouse.
Here is the part # of the wheels I got.
Pro Comp Xtreme Alloy Series 7089
Les Schwab Tires recently added the Dick Cepek Mountaincats to their website.
Les Schwab Tire Centers - Your Performance Headquarters For Tires and Wheels
You will not find these on the Dick Cepek website, as they are exclusively made for Les Schwab Tires.
Made in the same molds as other Dick Cepek tires with the familiar staggered DC impression on the sidewall.
These tires are also made by Cooper, and are pretty similair in design to the Cooper Discoverer STT tire.
They showed me out in the bay when we turned the wheels/tires lock to lock that they cleared the body mounts and also the calipers.
In getting new wheels for your FJ Cruiser, the important thing to pay attention to is the off set.
Mine are zero.
He asked me if I wanted to step up to a 295 since that is what noworries is running, but I stayed with the 285s.
They look great and 33" is big enough for me.
I did not notice any loss of power at all coming into work on the backway, and also going home on the freeway where I was able to put the throttle down some.
Went with black Gorilla small diameter Tuner lugnuts that take a special adapter/key to take them off with.
The new tires fill the wheel wells much better than the smaller ones.
Here are some pictures for comparison.
265x70x17 Dick Cepek Mountaincats with factory alloys:
285x70x17 Dick Cepek Mountaincats with Pro Comp 17x8 7089 series wheels:
Corey is offline
