Old 03-21-2009, 03:19 PM   #221
Member Number: 23136
Re: Corey's FJ with a few mods!
I like your definition of few
Prepare like hell, and let it rip
Jaxboro is offline
Old 03-21-2009, 03:53 PM   #222
Corey's Avatar
Member Number: 2902
Jaxboro previously said: View Post
This part
Actually this thread was started on this site (this same thread is on four different Toyota sites) before the "Members Buildup" section was created.
When they created it, a moderator moved my thread to this new section and renamed my thread with the current title.
Corey is offline
Old 06-27-2009, 05:07 PM   #223
Corey's Avatar
Member Number: 2902
PowerFilm Solar Panel installed 6-27-2009
Normally I would post the installation of a mod like this in this ongoing buildup thread here, but I felt the addition of the solar panel was worthy of its own thread.
Here is a link to the installation of the solar panel.
Solar power for camping/overlanding trips installed 6 27 2009
Corey is offline
Old 07-10-2009, 02:52 PM   #224
Corey's Avatar
Member Number: 2902
Engel Wireless Thermometer and tent shelf installed 7-10-2009
Two mods today, been busy all morning.
First up is the new Engel Wireless Thermometer that I bought from Wil at Sierra Expeditions.
First pictures shows the transmitter next to the receiver for size comparison.
Second picture shows the transmitter sitting in the fridge.
I did not use the supplied Velcro to attach it anywhere, as I want the option of putting it where I want once the grub is packed inside the fridge.
Third picture shows the receiver that can display the time, outside temperature, and the fridge temperature.
It is off by a few degrees (higher on the Engel unit) compared to the readout that comes stock on the ARB fridge.
Not sure which is the more accurate, I guess I could get one of these dial gauge thermometers and set it inside to check it out.
I find the range on this though is not eighty feet like they claim, in fact when I had the receiver up on my dash it would not pick up the temp of the fridge, it showed the old temp from when sitting in my home.
These need to be real close, hence why I used the Velcro and stuck the receiver onto the fridge.
Links:
Next up is the "Bjorno Maggiolina roof top tent mod.
Saw a thread over on fjcruiserforums.com by Bjorno who has the exact same tent model I do, the AutoHome Maggiolina AirLand medium.
I found camping in mine last year there is no storage space in the tent, and having a shelf like this is nice to put your shows up on.
The shelf is to small to put my BadBags duffel on, and way to heavy too.
But it can be used to store other stuff besides shoes/boots.
I was gong to try and install mine without cutting out the thirteen ribs like he did, but I would have had to tie the shelf with something to the lifting mechanism of the tent, and that would be kind of a pain.
His method worked out pretty good.
I cut the thirteen ribs out, and set the 16" arms along the tenth inward support rib.
This puts it at an almost level position.
Pretty simple to do, you just bend the tabs over with some adjustable pliers so they will anchor into the top of the roof top tents area which is made that way to hold the custom pockets that AutoHome sells (comes stock on the higher priced Maggiolina models) to put up there to use as pockets to hold stuff in.
Before I put my dirty shoes into a dishpan and stored it on the bed.
Kind of in the way while I slept, this will be nicer not bumping into it during the night.
I can put my Cabelas LED lantern up there, a box of nosewipes, flashlight, or other stuff up there that normally lays on the bed and gets kicked around.
Here are a few pictures of the installation.
Links:
Bjorno's thread on how he made the shelf
ClosetMaid shelf model 51041 from Lowe's
Bjorno's was a different part number, but it appears to be the exact same one as his.
Corey is offline
