Old 09-10-2006, 04:58 PM   #31
Corey's Avatar
Member Number: 2902
Re: A few mods 7-25-06
Did you get a warranty on it?
I paid extra to get an extended warranty on mine too, in case anything goes wrong after the factory warranty is up.
With Cartoys, they will rip out a defective unit and replace it for free.
My key fobs are also covered for 4 years.
If I drop one and break it, I get a free replacement.
Corey is offline
Old 09-11-2006, 06:04 PM   #32
Corey's Avatar
Member Number: 2902
Not to rest upon Sundays small Maglite mod, I had yakked with Les Schwab Tires Saturday about the Cooper Discoverer STT tires I have been wanting.
They are unavailable right now in the USA almost in the stock size of 265x70x17 which equal 32".
He did locate a set of 4 this morning in Pennsylvania, and I had him get them shipped, they will be here in a week.
But...I changed my mind.
Les carries a tire made by Cooper for **** Cepek called the Mountain Cat.
They are so new they are not shown on **** Cepeks site, or on Les Schwabs site.
When you look at them, you can clearly see they are made from the same mold.
They changed the sides a bit, and a little on the tread, but you can see the mold is pretty close.
These are still actually Cooper STT tires in disguise
I got $200 for 4 of my stock tires that came on the rig.
Not bad considering I have 1,200 miles on them.
These tires are beefy!
They are actually quieter than my Wild Country TXRs I ran for the past 8 years on the 4Runner, but the tread is way more aggressive, a true mud/dirt/rock tread.
They want some feedback from me on these tires since they are so new.
They do have a low hum, and I hope that it gets louder as they break in.
I like loud tires
They also had one demo mounted to a really cool Les Schwab brand (Ultra) wheel called the Allied 891/892 in a 17x9, and they mounted it up.
I think they had that demo tire and wheel waiting for me since it fit the FJ just right
Nice wheels, and $128 each, about $75 cheaper than the AR Mohave Teflon wheels I was thinking about.
Anyways, I can not wait to get my rig off road for the Fall Colors Run coming up and test out these new bad meats.
If I like them well, I will get five of them sized at 285x70x17 and new wheels come spring to run as my spring through fall set, and the current set will become the fall through spring set.
Nice thing about having two sets is it makes them last quite a few years.
I did not opt today to replace the stock tire on the tailgate.
I will do that before winter.
What the heck?
The name D i c k is edited here.
It must be in the words not allowed.
Anyway, they are D i c k Cepek tires made by Cooper.
Corey is offline
Old 09-13-2006, 07:31 PM   #33
Banned
Member Number: 2259
Keep up the good work Corey. You're on a roll brother!!
Tony5150RN is offline
Old 09-13-2006, 07:37 PM   #34
Corey's Avatar
Member Number: 2902
Thanks Tony.
I think a few will be looking at getting these same tires.
I have a thread up in the tire section.
I really dig these meats.
Coming up soon:
Home brewed shovel mount for the stock FJ rack
OME lift, ARB bumper, and my old Warn XD 9000 winch
Corey is offline
Old 09-16-2006, 01:31 PM   #35
Corey's Avatar
Member Number: 2902
Home brewed shovel mount for stock rack
On my '91 4Runner I had made a home brewed shovel mount using the Yakima Snap Arounds, some long bolts, and some Yakima plastic wingnuts.
The shovel I had bought at Lowes hardware.
Since Yakima has the 10V Mighty Mounts that let me mount the Slee Hi-Lift mounts, I knew Yakima would have the equivalent of a mount that would let the bolt go vertically, but the mount would be horizontal.
With the bolt vertically, this would allow the same shovel I used before to be able to sit on top of the FJ Cruisers rack slats.
I called up Yakima and they were clueless.
The tech people there are trained to only tell you what fits your rack that they have in their rack guides.
The guy I spoke with said I had to use Yakima Universal Mighty Mounts, as that is all that fits.
I told him I beg to differ, but your 10V mounts fit perfectly, as that is what Slee turned me onto when I contacted him.
I told the Yakima guy I wanted a horizontal mount that had the same shape as the 10V.
He said he did not know, but I finally got it out of him that the 23H should fit.
Now was that so hard to tell me?
I ordered up a set from RackOutfitters.com and sure enough, they fit perfectly.
However my old bolts I had used on the 4Runner were a little bent, so I had to buy new ones.
The size you want is 5/16-18-4
Also since I took off two of my racks slats when installing the Hi-Lift mounts, the two slats left were to far apart to make the shovel work with its two holes that are drilled in it.
I had to add back a slat and move it in front of the most forward slat, and that worked out perfectly.
Here is a shot of just the 23H mounts on.
Here is a shot with the new bolts.
The other plastic Yakima wingnuts I had used were to small for the new bolts and the 5/16th nut that Yakima has you insert into the 23H.
Luckily I had some old 5/16th Yakima wingnuts laying around from some old Yakima thing I bought years ago.
You can also use a standard metal wingnut, but the advantage of using the Yakima ones are they are much bigger to grab onto.
And finally a few shots with the shovel in place.
One nice thing too about mounting it more forward like this is I can step up on the sliderz to get up and take the shovel off.
It turned out pretty good, and I have two of the 23H Mighty Mounts leftover that I can use for another project up on the rack.
Maybe the kitchen sink I can mount to them.
While I was up there working on the roof, I tried to finally mount my 48" Hi-Lift on the Slee mounts.
It is not going to happen.
Jack is to heavy, and I can not get close enough on the ladder to heft it up there.
Chalk it up to getting old.
I am still working with a friend on making a Hi-Lift mount for the spare tire, or I may end up getting the Demello Hi-Lift mounts for the side of the rack in the future.
Not as hard to put the rack on the side as it is trying to put it all the way up on top.
I do not see why everyone is in such a hurry to ditch the factory FJ Cruiser rack.
I like it a lot, and with a little creativeness, you can do a lot with it by fabbing up your own stuff like I did the shovel mount here.
With the two leftover 23H mounts and buying another box of four mounts (would use four mounts), I could fab up a nice jerry can mount adding back the fourth slat.
Corey is offline
Old 09-24-2006, 12:43 PM   #36
Corey's Avatar
Member Number: 2902
Sunday morning mod, the axe mount
With two leftover Yakima 23H Mighty Mounts and two of the hex bolts leftover also from the shovel mount project, I present you with my custom axe mount.
Went to Lowes and picked up a fiberglass handled True Temper 36" Premium Michigan axe, part number 118590.
Drilled two holes in the handle 21.75" apart after measuring the distance between the two bolts once they were mounted.
The axe fits neatly besides the shovel.
I am loving these Yakima Mighty Mounts.
It would be very easy to get another set and more hex bolts and mount a jerry can holder up there.
I may do that, but I would carry water instead of fuel.
I do not see why some are so fast to get rid of the factory FJ rack.
With a little imagination, this rack rocks, and I actualy like the look of it better than the Gobi racks.
Corey is offline
Old 09-26-2006, 02:16 PM   #37
bandi's Avatar
Member Number: 2261
Real Nice Write-up Corey !!!
[[[[[[[[[ DEMELLO FlatTop Bumpers ]]]]]]]]]
The "Bandi Mount" From ALL-PRO OFF-ROAD
bandi is offline
Old 09-27-2006, 07:31 PM   #38
Corey's Avatar
Member Number: 2902
Thanks Bandi.
Next mod?
ARB bumper, my old Warn XD9000 winch, and an OME 3" lift.
It has been fun modding this rig.
I think its a keeper.
Corey is offline
Old 09-29-2006, 05:01 AM   #39
Banned
Member Number: 1398
Nice job and appreciated write-up, Corey.
Kzoocruiser is offline
Old 09-29-2006, 09:05 AM   #40
Banned
Member Number: 2259
I just finished the vent visors, a very simple 5 -10 minute mod. The visors from Lund / AVP are very good quality. I'm still not sure I like the look though. I almost think that it looks goofy without visors over the two back windows even though they don't open.
