Old 01-05-2009, 01:48 AM   #1
Eagle Scout's Avatar
Member Number: 17710
Eagle Scout's BRAVO28POINT2
R.I.P. BRAVO28POINT2
May 2006 - June 2009
[/center]
My first experience with off-roading was when I served in the military as a Long Distance Reconnaissance Scout. Back then I was both mounted and dismounted for countless operations but during the missions where I had to be mounted, I was put in charge as the driver of a Hatchback HUMVEE in which I had developed a flame for four wheeling in. With my use of HUMVEE B28 (Bravo Company-Vehicle # Two Eight), I had driven many lands of Pavement, Mud, Snow, Forests, Mountains, Desert, and Sand. As the team's driver and assistant team leader, I had found my self constantly servicing and modifying my HUMVEE to every extent until I took over the position of team leader; but even then, I still chose to drive my team everywhere because I would not have it any other way. As a homage to my beloved military HUMVEE, I have given my new love its name. BRAVO28POINT2
(Picture of original B28 HUMVEE to come later)
FROM THE DEALER
2007 Toyota FJ Cruiser
Titanium Silver
Upgrade Package 1 <ATRAC/Rear Locker>
CQ and C7 Convenience Packages
Curtain Shield Airbags
OEM Subwoofer
Build Date: May 2006
Purchase Date: June 2006
Armor
Intense Fabrication Pre-Runner front Bumper
Demello Hybrid Rock Sliders
Demello Front Skids
SUSPENSION AND TIRES
NITTO Terra Grapplers
Old Man Emu Front and Rear Coil-Overs(OME-895)
Old Man Emu Nitrochargers N140S FRONT STRUT HD
ToyTec Top plate spacers For a full 3" front lift
Spidertrax 1.25 Wheel Spacer Kit
Sparco Mudflaps
PERFORMANCE
Hyper Ground System by SUN automobile (Gain Torque & HP, Increases Fuel Mileage, Better Throttle Response, Reduces Emissions, Brighter Headlight, Reduces Audio Noise, and it is OEM Approved)
Scanguage II & Self Modified Mount
Safari Snorkel (Keeps the Dust out and I can go cross deeper waters)
AFE CAI (Silliconed and sealed to work with the Snorkel)
JBA Cat back exhaust (High Tuck Modified)
ADDITIONS
Body Mount Chop(Thanks to JROCK)
Tractor L Shape custom Shifter (Ebayed, Self Painted and welded)
IMP Tranfer Shifter
PIAA Sports Horns
12V Plug Ins (2 Extra in the center to the right of the shifter for more recharging of random batteries that need recharging!)
Blacked out Bezel/Door Handles/Side Mirrors/A-Pillars/Interior Dash (When I am bored, I black out stuff)
COMMUNICATIONS
Cobra Handheld CB Radio/ Bandi Mount
Antenna – 4' and 3’ Firestick/CB
Cobra "Walkie Talkies"(For Dismount Purposes)
LIGHTING
PIAA 580 Drive lights
Hella Rallye
American Titan HID HeadLights
Smoked out Signal and tail lights
2 x Oznium Flexible Super Thin (red) LED Dome Lights
7" Headlight Rock Guard
TOOLS,TRAIL, & RECOVERY EQPT.
QuickAir X 2000 Air Compressor (Mounted in the Engine Compartment, 200 PSI Max Pressure, 100% Duty Cycle, Will never Over heat on you so it can continuously work for you.)
Quick Air 10lbs Co2 tank
Staun Tire Deflators
MAXTRAX (those Big Orange Cheese grader thingys that work really well when you are stuck in mud, sand, or snow)
Hi-Lift Jack
Shovel
Axe
Smitty Built Recovery Strap
Fire Extinguisher w/ mount
Fuel Can Option: 2 x Wedco 5.3 gal. Jerry Cans (gas)
Fuel Can Mounted on Rear Tire Mount. (Thanks to JROCK)
GEAR STORAGE
OEM Roof Rack (Purdchased Used)
Fourtreks HiLift Jack roof rack Mount
Fourtrecks Dual Tools roof rack Mount (Shovel/ Axe Mount)
Springtail M-PAC rack and MOLLE gear
Springtail M-PAC Side Rack
Rear Door Cargo Net
Toyota Cargo net
More to come later...
My deceased FJ (R.I.P.):
BRAVO28POINT2
My new FJ Build:
(Shhhh.... Secret Secret)
Eagle Scout is online now
Old 01-05-2009, 01:49 AM   #2
Re: Eagle Scout's BRAVO28POINT2
MODIFICATIONS I'D LIKE TO PUT IN THE SPOTLIGHT:
PERFORMANCE
A good Truck is nothing without its performance on and off the road. Whether if you are A desert Rally Racer or a Mountain Rock Crawler, everything matters. Here are a few Mods I have put into my engine so far.
Hyper Ground Systems by SUN Automobile
On a normal system, electric current flows from a positive terminal to a negative terminal through the car body. But there are much resistance at connectors of body, engine and transmission. The resistance disturbs this flow of electricity to a degree that electrical components such as computer, lamp and spark plugs cannot perform at their peaks. In order to get the highest performance out of any vehicle, it is necessary to achieve a maximum electricity flow with the least resistance along its electrical circuit.
Such system has been used among Japanese WRC (World Rally Championship) racing teams for years. Since 2000, it has become the hottest modification performed by car enthusiasts in Japan. Its effect on automobile has been proven by dyno tests again and again. It gives an increase of torque from 3500 rev. 35kg to 4800 rev. 40.9kg and an increase of horsepower from 280ps to 305.9ps. It provides a faster engine start up, Smoother and Faster Throttle response, Increased engine Torque, 15% (more or less) better mileage, Lower density of HC and CO for cleaner exhaust gas, Improved Car Audio sound quality, and Brighter headlights. Since I have installed this system, I have truly noticed better mileage, More HP and Torque, and a better Throttle response in My FJ. I recommend everyone to get this.
AFE Cold Air Intake
I believe the colder input of air that you can put into your engine, the better the performance it will be. Most of us FJ owners have either settled for a TRD or a AFE. They are basically the same only that the AFE has a hole on its side that you can choose to plug up.
LUXURY
Luxury to me means something that makes everything easier upon your life. Here are some luxuries I am happy to have that makes 4 wheeling a whole lot easier.
QuickAir 2 Air Compressor
I got the mountable one so I could keep it installed in my Engine Compartment. It beats having to find a gas station after you run a trail to air up and it will always come in handy. Although I do also have a CO2 tank, you can always run out of CO2 so this is also a fail safe for that.
MY PERSONAL TOUCH
Since the dawn of Vehicle Modifications, people have always put their own personal cosmetics to their beloved Auto. After all, how can it be your own vehicle if you don't have a signature or trademark to go with it.
L-Shaped Shifter and IMP Transfer Shifter
One of the more favorable mods and easiest is the simple personal touch of a shift knob. I for one grew up watching Japanese Animes with Futuristic Gianormous Robots that can turn into Jet Fighters that the characters pilot and this is where all my influence originated for the L-Shaped Shifter. I simply searched for months looking for one and I finally saw an old Tractor shifter on Ebay for the min. bid of $1. I bidded on it, won a week later and paid the $3 shipping fee. It was originally Amber color with sparkles until I painted it Black. I ended up cutting part of my shaft to put on the new L-Shifter.
Scangauge II Bracket
I always like the Idea to not having to look too far from the road to look at your gauge. Here is my Idea & Solution. Fabricate a bracket and mount it to the lower part of the A- Pillar Handle. (Fabrication honors to JROCK)
BRAVO28POINT2
My new FJ Build:
Old 01-05-2009, 01:50 AM   #3
BRAVO28POINT2
My new FJ Build:
Old 01-05-2009, 01:51 AM   #4
My Wish List
Everyone has one, so here is mine. The mods I will one day have.
MAN-A-FRE Aux. Tank, OME Heavies Rear ,Custom Roof Light rack, , PIAA Fog Lights, GPS, my alloy wheels blacked out ( Yes I want to stick with stock alloys), Custom Paint Job(Dark dark Gray all around with no white roof, Optima Duel Battery, Solar Panel, WiFi/ Cell phone Reception, Demello Rear Bumper w/ Hitch, RED LED lights in Dash, Valentine one Radar Detector w/custom mount, Rear Winch, Fiberglass fenders,Total Chaos or Camburg LTS, Maybe Icon Stage 3, Reverse Cowl hood, Tinted Windows, Etc...
BRAVO28POINT2
My new FJ Build:
Old 01-05-2009, 01:54 AM   #5
GTKrockeTT's Avatar
Member Number: 15581
about time ivan....tagged for later viewing.
GTKrockeTT is offline
Old 01-05-2009, 01:59 AM   #6
GTKrockeTT previously said: View Post
Thanks Doug! The reason why it took me some time was because I wanted to have something to show for instead of having a mostly stock vehicle on display. Everyone has seen one of those...
BRAVO28POINT2
My new FJ Build:
Old 01-05-2009, 09:35 AM   #7
Wholesalestunna's Avatar
Member Number: 22561
Send a message via AIM to Wholesalestunna
Looks good I wish we had snow
“Blessed are the peacemakers, because they will be called the sons of God.” - Matthew 5:9
Wholesalestunna is offline
Old 01-05-2009, 09:45 AM   #8
mattmainster's Avatar
Member Number: 11822
Send a message via AIM to mattmainster
To think that beast was in my driveway yesterday....very nice!
mattmainster is offline
Old 01-05-2009, 10:39 AM   #9
Biff...'s Avatar
Member Number: 19882
Very nice Ivan. Good seeing you on Saturday.
NRA LIFE MEMBER
The late, great Colonel Jeff Cooper postulated four cardinal rules of gun safety. 1) All guns are always loaded, and treated as such. 2) Never allow the muzzle to point at anything you are not prepared to see destroyed. 3) Do not let your finger enter the trigger guard unless and until you are in the very act of intentionally firing the weapon. 4) Be certain of your target.
Biff... is offline
Old 01-05-2009, 11:08 AM   #10
BigDouggieDoug's Avatar
Member Number: 10055
BRAVO28POINT2 is looking hot! I like the Intense Fabrication front bumper and the PIAA lights, and the smoked-out signals.
____________________________
Trail Snail
BigDouggieDoug is offline
