Old 08-18-2009, 09:41 PM   #11 (permalink)
BamaBleach's Avatar
Member Number: 7390
Re: BamaBleach's FJ40 buildup
1911 previously said: View Post
Great build!
The 3FE is a super great motor; I would love to put one in my 40. You will need to put an oxygen sensor in your exhaust for it. Probably be best off to use the wiring harness from the 62 also.
I'm envious of your Toy Box. Where are you going to put the gas tank now?
I don't want to move my gas tank, so I'll be going with an Orion transfer case instead of a Toy Box.
Keep posting reports and photos please.
I hear the 3FE really shines behind a manual transmission. Guess I'll find out first hand! The 62 had 2 oxygen sensors so, you're right, I'll have to add those in. I've got some friends with some electrical experience offering to help me so, along with them and the FSM, it shouldn't be too difficult of a swap. I'm going to use as much of the 62 harness as I can.
The only other big obstacles is brake booster clearance and adding an external fuel pump. Others who have done the swap suggest using the MSD 2225 so that's what I'll go with. Oh, and I'll also have to bore out the flywheel a bit to account for the larger sized bolts used with the 3FE setup.
I've been wanting a Toybox since I got the Cruiser so I'm real excited about it. My gas tank is under the passenger seat so I don't think I'll have to move it. We'll see.
Probably won't get much done this weekend because of a rock race our local club is hosting.
'73 FJ40 --- Build Thread
BamaBleach is offline
Old 08-18-2009, 10:15 PM   #12 (permalink)
puulboy's Avatar
Member Number: 8494
Nice looking 40. The transplant should make you much more intimate with your rig. I look forward to watching your progress
thanks
Don
AZFJ founding member
www.wikidfj.com under construction
http://wikidfj.blogspot.com/
Member build page
http://www.fjcruiserforums.com/forum...other-gal.html
I would like to thank the following companies for working with me on Wikid
Total Vision Products
Allan Phillips Racing
Camping Labs
Baja Racks
Ricochet Skids
Overland Warehouse
puulboy is offline
Old 08-19-2009, 08:05 AM   #13 (permalink)
1911's Avatar
Member Number: 4994
BamaBleach previously said: View Post
DOH! I thought you had a later 40 w/ the tank between the frame rails (like mine). No, you won't have to move it - plenty of real estate under there for you.
N5MUD
TLCA # 16550
High Desert Cruisers
1911 is offline
Old 09-11-2009, 02:02 PM   #14 (permalink)
fka Memphibious FJ
Bert's Avatar
Member Number: 9778
Updates?
-Bert.
Architectural Assault Vehicle
Rogue Architect for Hire
Bert is online now
Old 09-11-2009, 02:25 PM   #15 (permalink)
VT_RainMan's Avatar
Member Number: 10271
Yes, please... This is the second time I have read this thread. It's a good read and one of my dreams some day! You have the same year 40 I want.
2007 FJ 6MT black -n- black
VT_RainMan is offline
Old 09-16-2009, 02:35 PM   #16 (permalink)
BamaBleach's Avatar
Member Number: 7390
I do have some updates but I want to get a little bit more done before I add the pics. I'm halfway done with the toybox install and wanted to finish it before I posted an update.
We did come up with a pretty slick modification to my reverse light switch. I posted a detailed write-up of it on ih8mud and marlin's website. The guys at Marlin liked it enough to add it to their "Tech" section so that was pretty cool.
If you're interested it can be found here:
Modified Reverse Light Switch for Toybox users
Thanks for encouragement! It helps motivate me.
Old 09-16-2009, 07:46 PM   #17 (permalink)
cheddar's Avatar
Member Number: 30015
Man thats a wicked looking build so far.
Keep it up
cheddar is offline
Old 09-18-2009, 07:18 AM   #18 (permalink)
Bigpappapunk's Avatar
Member Number: 30694
Stoked to hear/see updates
Bigpappapunk is offline
Old 12-11-2009, 01:23 PM   #19 (permalink)
BamaBleach's Avatar
Member Number: 7390
Wow, kind of embarrassing that I haven't updated this thread in so long.
So after getting the 3FE out of the 62 and ordering some parts it was time to get down to buisness.
I was able to find a torrent file for the pdf version of the H42 repair manual. I needed this because I needed to replace the stock output shaft with one supplied with the marlin crawler H42-to-toybox adapter kit.
The new Marlin output shaft:
Old 12-11-2009, 01:23 PM   #20 (permalink)
BamaBleach's Avatar
Member Number: 7390
Replacing the output shaft took some time because we didn't have the best pullers to work with. The manual calls for SST's that we didn't have.
For a good write-up on this process look here:
Marlin Crawler ToyBox Install Instructions
Here's a few pics of us doing it:
Hack job on a bolt head that we used for the puller:
Had to wedge the end of a file in so the bolt couldn't "ride out":
