Go Back   Toyota FJ Cruiser Forum > Supporting Vendors > Metal-Tech
Metal-Tech Metal-Tech
Old 04-01-2008, 04:37 PM   #1 (permalink)
Member Number: 17823
Question SAWs
Hi
I am about ready to purchase the 3" lift including the C/O's for the front, and the rear springs and shocks. Is there any reason you are aware of that should necessitate me having the install done by a shop. I believe I can perform the install, but I have heard of different issues on the forums about people having bad installs done. What does this mean? How would one do a bad install? Its seems that it could really only be done one way? Thanks for any input.
gilessankey is offline
Old 04-01-2008, 10:33 PM   #2 (permalink)
psheat's Avatar
Member Number: 12532
Re: SAWs
gilessankey previously said: View Post
Hi
X2 also are there any specials like I see in some older posts?
Epictetus:
We must not believe the many, who say that only free people ought to be educated, but we should rather believe the philosophers who say that only the
educated are free.
psheat is offline
Old 04-01-2008, 10:50 PM   #3 (permalink)
Member Number: 12722
Re: SAWs
You can install these if you are comfortable with doing some minor automotive work. I believe most of the problems come from when the shops adjust the coilovers wrong. The SAW system has been great on my FJ with almost no adjustment of the coilovers. You should have the allignment done after install. Good luck!
Craig
FJ_Craig is offline
Old 04-02-2008, 05:44 PM   #4 (permalink)
LT.
LT.'s Avatar
Member Number: 6786
Re: SAWs
You can do the installation yourself with no problem. I would recommend renting a tie rod end puller from Auto Zone since it is hard to get the coil over into position with the tie rod in place.
We will set the correct pre-load for you, for the 3" lift and make sure that all the shocks and coil overs have the right amount of nitrogen charge.
'76 FJ40 running on Propane.
1964 FJ45LV, 6.0L Vortec, 700r4, FJ62 split case, FJ62 axles, Power Steering, Spring Over, 35s, OD green.
Metal Tech
LT. is offline
