Skoaltrain previously said:
I would do it myself but lack some of the tools needed.
Thank you in advance!
Take some of the money you would have used for install, buy a decent set of ratchets, sockets, and jack stands.
There are plenty of install guides on this forum and if the spacers up front mount to the top of the coilover with out needing to remove the top plate, then this saves you a trip to a mechanic shop to have them do this. If not, i would suggest taking it to a mechanic with a wall mounted spring compressor to have this done (50 bucks) then go back home and install.
Then after a few days of driving, once everything has settle a little, go get an alignment (about 50 bucks as well).
If you ever have something go wrong with your vehicle, the more you have worked on it, the more you will understand and be able to fix it yourself (aka save lots of money)
