Creative Minds Needed! - Toyota FJ Cruiser Forum
» Auto Insurance
» Featured Product
Old 02-08-2012, 09:11 PM   #1 (permalink)
Member Number: 25965
Hey guys I am currently working on a make-shift hi-lift/maxtrax/rear back up light mount on my stock tired carrier. I have almost figured everything out except the lighting. I already have a power line ran to the back for old lights I had on my roof but I removed the roof rack and need a new place to mount them. My main question is how to I neatly run a wire out there with out the wire showing or making a mess. Any input would be overly appreciated, ive been pondering this for days and have found my self stuck in a rut.
thanks Joe
smokenjoe is offline
Old 02-08-2012, 10:24 PM   #2 (permalink)
Banned
Member Number: 36631
Re: Creative Minds Needed!
Run wire through door. Drill a hole through a bolt that holds tire carrier on and run Eire through hollowed bolt. Silicone wires into bolt.
I've never had mine apart but atleast this way you can always replace bolt and it would cove hole.
DOfj is offline
Old 02-08-2012, 11:03 PM   #3 (permalink)
you wouldnt happen to have pictures of the process of how to do this would you...or if anyone else does that would be great...i was afraid of the whole drilling threw things after my roof went all wrong when i did that myself haha
Old 02-09-2012, 09:58 AM   #4 (permalink)
Banned
You need to put the bolt on a drill press and hollow out the center of bolt.. I have some titanium hollowed out bolts that I will try and post a pic later when I get home.
DOfj is offline
Old 02-09-2012, 05:18 PM   #5 (permalink)
Banned
Here is a hollowed out titanium bolt
Run wire through bolt and into rear door.
DOfj is offline
Old 02-09-2012, 06:51 PM   #6 (permalink)
Member Number: 50658
you could just run it into the door using the existing wiring as a way in and then drill a hole in the door and grommet it.
there is already wiring running to rear wiper and lock inside the rear door. use that loom as your access point and then route it to where you need it.
ShtLuck is offline
