Old 04-09-2007, 10:39 PM   #1 (permalink)
stunaep's Avatar
Member Number: 10583
two tabs with welded nut underneath to attach something...
i notice that there appears to be two tabs that are sticking out that looks like some kind of skid plate either was there, or could be added...
it would cover the area near the front drive train, behind the plate that covers the oil pan.
if anyones fj came with that plate, will you take a picture of it! i'll go to the dealer and get it put on.
i know there are a lot of open threads on the vehicle for adding things, so it could just be that.
thanks,
--c
stunaep is offline
Old 04-09-2007, 11:08 PM   #2 (permalink)
helocat's Avatar
Member Number: 2312
Re: two tabs with welded nut underneath to attach something...
Since the GSJ15 frames are also the Toyota Prado Toyota Australia: Prado - Home page
(Similar to the Lexus GX avlaible in the US) frames used over seas they have extra bits of engineering for the other models. (Cool stuff like 3.0 ltr Turbo Diesel engines!)
This frame is one of the true and key real Land Cruiser parts to our trucks!
stunaep previously said: View Post
thanks,
--c
Mark Hawley
2007 GSJ15 - 1997 FZJ80 - 1994 FZJ80 - 1978 FJ40 -1985 Mini pickup
TLCA #1137 (yup, 100% Cruisers since I was 17!)
www.metaltech4x4.com Metal-Tech is an Marlin Crawler dealer now! Want to crawl? Direct bolt in replacement transfer cases will 4x your low range!
helocat is offline
Old 04-09-2007, 11:31 PM   #3 (permalink)
tisilverFJ's Avatar
Member Number: 1394
thanks,
--c
This could be your answer.
Under carriage mounting tabs.
TLCA#16292
Toytec custom coil lift,SS brake lines. PM me for Discountshttp://www.toyteclifts.com/fjcruiser...ruiserliftkits
All Phase Offroad diff skid,engine skid,Hi-Lift mount,axe/shovel mount,HD LCA frame mounts.
Spidertrax spacers.
All-Pro HD LCA's,Bandi mount.
FabFours front bumper w/PIAA lights
Stock Toyota steel wheels with 35" MTZ's.Gas/water cans mounted to stock rack. Midland hand-held CB. Thule fairing. OEM rock rails. A-Trac/Locker hack.
tisilverFJ is offline
Old 04-09-2007, 11:56 PM   #4 (permalink)
stunaep's Avatar
tisilverFJ previously said: View Post
well, at least i know i didn't get anything stolen! i'm going to take this picture and make my own skid plate! if it's only a couple bolts... a slab of steel and two bolts, and viola!
thanks!
stunaep is offline
