Old 04-11-2007, 08:18 PM   #1 (permalink)
VP23271's Avatar
Member Number: 9460
Added a Ski/Snoboard Rack and removed the thumb screws
I picked up a Yakima Fat Cat 6 Snowboard rack and installed it last weekend. I like the rack for it's low profile. One thing that I noticed when installing the rack was that all of the cross rails are held in place by thumb screws. Removing 2 rails with my snowboards and new Yakima rack attached could not be any easier for a thief. He would not even need a single tool to remove it from my FJ. So I made a trip down to Home Depot and picked up a set of hex head cap screws and washers to replace the stock thumb screws. I was hoping to pick up a set of tamper resistant torx screws, but Home Depot did not have any. The hex head cap screws will do for now, but I plan on replacing them after I find some torx online.
The screw size is metric, 6mm x 30mm long.
VP23271 is offline
Old 04-12-2007, 07:56 PM   #2 (permalink)
NTX_FJ's Avatar
Member Number: 5995
Re: Added a Ski/Snoboard Rack and removed the thumb screws
I did just that last Fall with a FatCat 6. However, I attached the rear ski rack to the back round part of the factory rack--that way I only had to worry about the front one (attached to a crossbar) being stolen. I also put no head (allen wrench) bolts in the crossbar for the front rack.
Just a suggestion, it is very easy to load the ski rack standing on the rear bumper with the rear-most rack installed on the rear part of the factory rack (and not a crossbar). I also put my skis inside the FJ at night. It meant a little more work in the morning but I slept better knowing they were a little safer.
Btw, the FatCat 6 held 7 pairs of normal shaped skis.
Black AT, CQ, GY, UR, SF, WT, SD, E0, P4, Vin 40739
Blue (wife's 2wd, insert bunch of letters here) Vin 4832
NTX_FJ is offline
Old 04-12-2007, 10:25 PM   #3 (permalink)
VP23271's Avatar
Member Number: 9460
NTX_FJ previously said: View Post
Thanks NTX_FJ, I actually just moved the rear rack last night to the same position as yours, except I mini/half racked my stock rack last week. Even with the Donahoe Lift and 33" tires, I am still able to park my FJ in the garage. If I can find button head torx screws I will post price and the manufacture. I took pictures and will try to post.
VP23271 is offline
Old 04-12-2007, 10:31 PM   #4 (permalink)
VP23271's Avatar
Member Number: 9460
Half/Mini Rack with Yakima Fat Cat 6 Snowboard/Ski Rack
(I am new, so I hope the attached pictures work)
added-ski-snoboard-rack-removed-thumb-screws-rack_3_a.jpg  added-ski-snoboard-rack-removed-thumb-screws-rack_1_a.jpg
VP23271 is offline
Old 04-13-2007, 12:47 AM   #5 (permalink)
potatomutato's Avatar
Member Number: 6914
i have the same set up and replaced the thumb screws as well. however, it's still very easy to rip off.
if i plan to leave them on for an extended period of time, i don't. i just take off the crossbars with the fat cats still attached and leave them in the garage. anyone with a hex key can rip those puppies off just as quickly as someone with thumbs.
the fat cats are cool as heck! good choice.
potatomutato is offline
Old 04-13-2007, 01:00 AM   #6 (permalink)
daPitbull's Avatar
Member Number: 9386
mini-me rack with yakima crossbars. You can attach any of the yakima stuff on without it being so high...
daPitbull is online now
