Old 07-30-2007, 10:42 AM   #1 (permalink)
CtheProducer's Avatar
Member Number: 9253
Question Alt. Problems
So I was doing some fording/mudding this weekend and now have a wonderful high pitch noise. It gets louder as I go higher in RPM's and sounds like the FJ is 30yrs old
Anyway, from all the searching I have done it seems I have damaged my Alternator. I am going to take it in to get fixed but I am really wandering if there is any type of alt. that would be better "mud/watter" suited. I saw a thread saying FJ's have one of the best alt's ever made. Just thought I would ask though. Thanks!!
Voodoo Blue 4x4, All Pro FWB, OME lift, TRD CAI, Pro Comp Xtreem muds 285/70/17, Uniden PC 78 Elite w/ 4' firestick, MAN-A-FRE engine skid, Scuba Driver, Safari snorkel
CtheProducer is offline
Old 07-30-2007, 10:44 AM   #2 (permalink)
homedad's Avatar
Member Number: 10257
Re: Alt. Problems
CtheProducer previously said: View Post
I have a dollar that says the alt. is fine...you burned up the pullies....i'm on set #3...all covered by the dealer
I like Tator Tots...
homedad is offline
Old 07-30-2007, 10:55 AM   #3 (permalink)
Brian - VABeach's Avatar
Member Number: 1584
Re: Alt. Problems
Homedadr is our expert vehicle thrasher so he knows more than I do about this stuff, but the noise could also mean you've gotten water in your rear differential, and need to drain and refill it with diff fluid.
http://www.fjcruiserforums.com/forum...ather-mod.html
Brian - VABeach is offline
Old 07-30-2007, 11:04 AM   #4 (permalink)
Member Number: 9253
Re: Alt. Problems
homedadr previously said: View Post
Thanks for the info, I just though it could be the alt. by the way it sounds. Is there any type of upgrade for the pulleys to make them more mud/wter friendly?
Brian - VABeach previously said: View Post
Homedadr is our expert vehicle thrasher so he knows more than I do about this stuff, but the noise could also mean you've gotten water in your differential, and need to drain and refill it with diff fluid.
I just did the rear diff. last weekend. The breather for the front diff is up in the engine bay, so I thought I didn't have to worry about getting that contaminated?
Old 07-30-2007, 11:09 AM   #5 (permalink)
FJ LE's Avatar
Member Number: 9297
Re: Alt. Problems
After I came back from Ouray, I started to get a kinda loud "motor" noise in the engine compartment when turning the steering wheel. Took it to the dealer and they didn't find anything. I still have this sound specially when I turn and back out from my garage. It doesn't matter if it's at cold start or not.
I figure I might have to take it to another service department/dealer.
TRD SE w/ Full BudBuilt Skids, All Pro Link & Shock Skids, Diff. Armor, Spidertrax w.s., 3" lIFT, OMEs, Belstein/Procomps, Lucrum Winch Mt., Maxxis M/Ts, Scuba Driver Breather mod., XM Radio, CB, Magellan GPS, Inverter, PIAA 540 Fog Lights, 2007 FJ Summit Memories!
TLCA Member # 17635
FJ LE is offline
Old 07-30-2007, 11:10 AM   #6 (permalink)
Member Number: 1584
Re: Alt. Problems
Didn't realize you'd done the Rear Diff Mod already, my bad, please disregard my previous Post.
Old 07-30-2007, 11:15 AM   #7 (permalink)
Member Number: 9253
Re: Alt. Problems
FJ LE previously said: View Post
That sucks, Yeah this nois is constant, no matter what and only increses with more throttle.
No prob. man, I love that thread.
Old 07-30-2007, 11:30 AM   #8 (permalink)
nic1010's Avatar
Member Number: 10102
Location: metro detroit, MI (rochester/shelby twp, but we call Toledo, OH home)
Send a message via AIM to nic1010
Re: Alt. Problems
I would call it more of a whine than anything....
yep, there's a good # of us that now have the sound, post Ouray (water crossings).
There is a thread already going on this. You might have some luck there. Ours has quieted some after we took it in for maintenance, but its not entirely gone. The guy who washed it at the dealership put it on a lift and sprayed out the undercarriage really well--LOTS of mud came out. Might want to give her a really good spray and see if it helps. We're pretty sure we'll be replacing pulleys soon.
Worth the read, here ya go:
weird whine?
good luck!
I am here to LIVE OUT LOUD!!!!
nic1010 is offline
Old 07-30-2007, 11:49 AM   #9 (permalink)
Member Number: 9253
Re: Alt. Problems
nic1010 previously said: View Post
weird whine?
good luck!
Thank for the thread. I was searching noise, guess thats why it didn't come up.
Old 07-30-2007, 03:33 PM   #10 (permalink)
homedad's Avatar
Re: Alt. Problems
All the way in Virginia....and I'm still the thrasher.....Damn.....the rear diff noise won't change with rpm...only speed....the alt. is one of the best stockers I've seen...anyone burn one up yet??? no..they didn't.....clean the belts and pullies with 2 million gallons at the car wash...high preasure...if that doesn't work then it's too late and you need some pullies....Toyota has plenty of them in stock...they changed out mine twice and never had it longer then 5 hours to do it....again..good luck...Kurt
homedad is offline
