Old 08-09-2007, 07:06 AM   #1 (permalink)
FJ Gooch's Avatar
Member Number: 12477
Send a message via AIM to FJ Gooch
Upper/lower Windshield
I pulled this from a site sorry the pictures probably wont show
NVH
NV009-06
Title:
UPPER/LOWER WINDSHIELD
TICK NOISE
Models:
'03 - '07 Toyota
September 18, 2006
Introduction
If a creak, tick, or rattle noise is heard at the top or bottom of the windshield, the source of the noise may be the two windshield stoppers bonded to the top of the windshield or the windshield retainers bonded to the lower edge of the windshield. This bulletin provides the recommended repair procedure to eliminate these types of noises from the windshield area.
NOTE :Some vehicles have both stoppers and retainers while others may only have stoppers at the top of the windshield. Use the chart in this bulletin to determine the location of the windshield holding devices.
Applicable Vehicles
^ 2003 - 2007 model year Toyota vehicles.
Required Tools & Material
Warranty Information
Applicable Warranty*:
This repair is covered under the Toyota Comprehensive Warranty. This warranty is in effect for 36 months or 36,000 miles, whichever occurs first, from the vehicle's in-service date.
* Warranty application is limited to correction of a problem based upon a customer's specific complaint.
Required SSTs
Pin Locations
Repair Procedure
Upper Windshield Glass Stoppers:
1. Remove both sun visors and both A-pillar garnishes, and then carefully lower the front of the headliner to gain access to the windshield stoppers (refer to the appropriate model year Repair Manual for the proper procedure).
NOTE :It is very important that the front of the headliner be lowered carefully and slowly.
Applying too much downward force on the headliner will cause it to develop a permanent crease in the surface material.
The stoppers are located on the inside of the passenger compartment behind the windshield glass blackout section (near the top front edge of the metal roof opening). The stoppers are typically located 20 - 25 cm (7.9 - 9.8 in.) inboard of the top corners of the windshield glass.
2. Cut OFF the tip of the plastic stopper as shown in the illustration.
HINT:
It is sometimes necessary to bend the metal body tab down to gain access to the shaft of the stopper.
3. Once the tip of the stopper has been removed, use a screwdriver to open a gap between the roof panel and the remainder of the plastic windshield stopper.
4. Test drive vehicle prior to reassembly to confirm that the noise has been eliminated.
5. Reassemble the vehicle.
Lower Windshield Retainers:
1. Carefully remove the plastic cowl cover at the base of the windshield and store it in a safe location for reinstallation later (refer to the appropriate model year Repair Manual for the proper procedure).
2. Locate the lower windshield retainers.
The retainers are typically located 140 - 200 mm (5.5 - 7.9 in.) inboard of the lower corners of the windshield. The flat portion of the retainer is adhered to the backside of the windshield with double-sided, foam-backed tape.
3. Use a "Mini" Hacksaw with a fine tooth 10-inch blade to cut OFF the pin portion of the glass retainer flush with the flat portion of the windshield retainer (diagram below shows the windshield retainer location to cut off the plastic pin).
4. Test drive the vehicle to confirm the elimination of the noise.
FJ Gooch is offline
Old 08-11-2007, 05:41 PM   #2 (permalink)
fjcruzer123's Avatar
Member Number: 9059
Send a message via Yahoo to fjcruzer123
Re: Upper/lower Windshield
You're right, no pics!
Gotta love the last instruction:
"Reassemble the vehicle."
“Can you do Voodoo like I do?”
“Not all who wander are lost…”
http://www.myspace.com/fjcruzer123
http://www.zombiehunters.org/
fjcruzer123 is offline
Old 08-12-2007, 12:07 PM   #3 (permalink)
FJ Gooch's Avatar
Haha Yeah Gotta Love Good Old Toyota
Haha Im Working On The Pics I Was Using The Server From School When I Posted It And The Server Didnt Host The Pictures So I Have To Log On From Home
FJ Gooch is offline
Old 08-21-2007, 08:02 PM   #4 (permalink)
Racer001's Avatar
Member Number: 12889
Send a message via AIM to Racer001
you dont need to capitalize each word
Racer001 is offline
Old 08-26-2007, 08:47 AM   #5 (permalink)
FJ Gooch's Avatar
haha sorry about that thats my work computer that does that cuz it should only be use for work lol
FJ Gooch is offline
Old 08-26-2007, 03:50 PM   #6 (permalink)
Member Number: 11833
Your work computer capitalizes each word?
<--- IT
Black Cherry
+Goodies
Stock for now
MarkBNJ is offline
Old 08-27-2007, 08:54 AM   #7 (permalink)
FJ Gooch's Avatar
yeah thats how it is here at lexus for the dispatch comps its wierd
FJ Gooch is offline
