Old 08-18-2007, 01:50 PM   #1 (permalink)
Racer001's Avatar
Member Number: 12889
Send a message via AIM to Racer001
Question on Accessories, wiring, and switches. Help please!
Hey!
I have a quick question. Now, if I get a set of brush gaurd lights, I assume there are a few pieces. You'll have the lights and associated hardward, then you'll have a foglight switch to put in the control panel, then im assuming you will also have a Toyota wiring harness to install.
Are instructions for installation included with the accessory? Am I right for the most part about all the pieces, switches, and wiring all coming together?
Just curious
Also, why are the dang switches so expensive?
Racer001 is online now
Old 08-18-2007, 02:14 PM   #2 (permalink)
Member Number: 12825
Re: Question on Accessories, wiring, and switches. Help please!
You are correct that most light kits, come with some wire, a switch and general instructions. Some of the better ones, will have a relay and a fuse thrown in there, and better instructions, but I don't think that any kits come with a special harness adaptor for a specific car.
acfj40 is offline
Old 08-18-2007, 02:20 PM   #3 (permalink)
Racer001's Avatar
I was talking about Toyota parts specifically. Sorry, I should have made that clear. Does your answer still apply? lol thanks for the help!
Old 08-18-2007, 03:09 PM   #4 (permalink)
If you are talking O.E.M. accessories, than I'm not very familiar with the FJ wiring, but most of the new cars come with a wire harness that is prewired for all the possible options to be offered. I'm not sure what an O.E.M. light kit consists of, but once you get all your stuff together, it should be plug and play, type of deal. Sorry, I don't think I'm helping you out very much here.
acfj40 is offline
Old 08-18-2007, 04:33 PM   #5 (permalink)
Racer001's Avatar
Anyone else?
Old 08-19-2007, 11:24 AM   #6 (permalink)
Racer001's Avatar
Well after seeing about the Atrac hack where the wiring is already there and you just need a switch, I am a little more comfortable to assume that the wiring should be there.
Old 08-23-2007, 05:38 AM   #7 (permalink)
Steve_53's Avatar
Member Number: 9264
Any additional wiring that is needed for a Toyota accessory will come with the kit, and will plug into existing connectors in the factory harness. In some cases (such as lights) the kit will also include a fuse and relay to be installed in a "reserved" slot in the relay box.
My experience with the Toyota "add-ons" is that they come with ALL of the parts you are going to need, and (relatively) good instructions.
Steve
2007 FJ: Titanium, 6MT, CQ, GY, UP1, C7, Z1. K&N Air Filter, Westin Nerf Bars, Stebel Air Horn, In-Channel Vent Visors, Parrot CK-3100 Bluetooth, Hardwired Radar Detector, Toyota/Garmin GPS, SAS fog lamp kit, Custom shift knobs, ATRAC Hack, SAS GM map light, Heated Multivex mirrors, Running light+turn signal mirror lamp mod, ScanGauge II, 200 PSI on-board air system, Siege Engineering Hammer 4 air horns, rack-mounted halogen back-up lights, VR3 backup camera.
Steve_53 is offline
Old 08-26-2007, 04:52 AM   #8 (permalink)
Racer001's Avatar
thank you Steve!
