Old 08-26-2007, 03:42 PM   #31 (permalink)
Member Number: 11952
Re: Garage door opener...what do you guys think?
Button availability. I found Radio Shack has several momentary contact switches. Some (red or black cover) even look like yours. You push it like the opener's own button, and let go. If you don't see these at Radio Shack, ask. They are usually in a parts drawer in the back of the store. Cost varies, but is usually between $2 & 4. These are round, so usually a simple drilling of a blank FJ switch mount is all that is needed.
Again, thanks for the original idea, impetus. Rep point to you!
rons8888 is offline
Old 08-27-2007, 10:38 AM   #32 (permalink)
Member Number: 9331
What a neat mod!
Alien is offline
Old 08-27-2007, 11:10 AM   #33 (permalink)
04e46conv's Avatar
Member Number: 13320
That look real clean!! Nice work!!
04e46conv is offline
Old 08-27-2007, 08:19 PM   #34 (permalink)
mrod81's Avatar
Member Number: 13014
Hey guys,
Thanks for all the postive feedback!
ITiTanium02I previously said: View Post
What was that button for before you did the mod. My FJ does not have that button.
Yeah i just got the button from FRY'S elecronics and painted after it was ready to be installed
fjsspr previously said: View Post
Looks like it came right from the factory!! Question? Do you still get the same range with all the dash interfering?
Yeah i do still get the same range i thought i had lost some but i tested it and measured the distance with the extra remote i have and it is the same...about 125ft away from the door
DEWFPO previously said: View Post
The paint on that button matches very well. What brand and color? DEWFPO
Paint is just flat black primer...i liked that one because it does blend in better than just regular flat black paint...to protect it i also put a coat of clearcoat on it...no special paint i dont have the can anymore but i just picked it off the shelf at kragen...take the switch cover and compare it to the tops on the spray paint cans.
mrod81 is online now
Old 08-28-2007, 06:52 PM   #35 (permalink)
tyf2002's Avatar
Member Number: 12944
Awesome idea! Rep points to you!
Do you have a button to clean out the garage?
tyf2002 is offline
Old 08-28-2007, 06:54 PM   #36 (permalink)
Member Number: 13134
Too cool! Nice write-up. Thanks for the instructions.
bluehi is offline
Old 08-29-2007, 07:10 AM   #37 (permalink)
Steve_53's Avatar
Member Number: 9264
I could certainly use a "clean out the garage" button!
Steve
2007 FJ: Titanium, 6MT, CQ, GY, UP1, C7, Z1. K&N Air Filter, Westin Nerf Bars, Stebel Air Horn, In-Channel Vent Visors, Parrot CK-3100 Bluetooth, Hardwired Radar Detector, Toyota/Garmin GPS, SAS fog lamp kit, Custom shift knobs, ATRAC Hack, SAS GM map light, Heated Multivex mirrors, Running light+turn signal mirror lamp mod, ScanGauge II, 200 PSI on-board air system, Siege Engineering Hammer 4 air horns, rack-mounted halogen back-up lights, VR3 backup camera.
Steve_53 is offline
