Old 08-25-2007, 07:38 PM   #1 (permalink)
use2b's Avatar
Member Number: 13289
Maint Req light stays on after oil change
Maint Req light stays on.
my 2007 FJ had the oil changed at 4800 miles but the light stays on, is there any procedure to reset this light ?
use2b is offline
Old 08-25-2007, 07:41 PM   #2 (permalink)
AceTechno's Avatar
Member Number: 4098
Re: Maint Req light stays on after oil change
use2b previously said: View Post
YES! If you read your owners manual that came with your car when you bought it it will tell you how to do this.
PERFORMANCE: Airaid intake, Gibson Exhaust, Royal Purple Oils
LIFT KIT: Toytec/Donahoe Racing 3", Spidertrax spacers
EXTERIOR: Rear Tail lite Guards, GoodYear MT tires, AP Sliders, PIAA Headlights/dome lites, Fourtrex, Hi-lift
COLOR: Voodoo Blue 4x2
AUDIO: Dice iPod interface
INTERIOR: ScanGuage II, Ellis Design Black Handles & Battery Clamp. Littlelite 12" map light W/ Dimmer.
My Build: http://www.fjcruiserforums.com/forum...shockwave.html
AceTechno is offline
Old 08-25-2007, 07:55 PM   #3 (permalink)
MudLovingFJ's Avatar
Member Number: 8945
Send a message via AIM to MudLovingFJ
here is how to reset the light: with tthe keys in the off position (no lights on the dash and no radio on) just press and hold the trip odo reset button. then turn the key to the on position, but dont start the truck. keep holding the button until the lines go away (you will know what im talking about when you see it). then the light is cleared for the next few thousand miles or so.
The So-Cal Safari Snorkel Install Guy 7 chicken necks installed to date
MudLovingFJ is offline
Old 08-25-2007, 08:08 PM   #4 (permalink)
use2b's Avatar
Thanks Guys , It worked.
I was stuck on page 102 where it only said to change the oil and nothing else.
use2b is offline
