mikesfj previously said:
Get the short shifter kit. It is a bit pricey for the TRD (I have this one), but it really makes shifting and driving the 6mt much nicer and sportier. Plus your shifter doesn't encroach the passenger side nearly as much in the higher gears. URD makes a kit also that uses the stock shift lever a spacer and an extension. The TRD gets you a spacer and an entirely new shift lever and of course, longer bolts. If you get either one of these, make sure you have some silicone sealant on hand when doing the change-out.
My fraternity brother and two year roommate had an older saab that had a real long throw from 4th to 5th, and being that he and his dad do lots of track events with other cars, he was pissed about the long throw. Instead of shortening the shift length ect. his dad simply told him that it was the "opportunity shift"
His dad explained to him that the opportunity shift was great for when you were out with a girl the first time or second and want to cross the touch barrier. Simply go from 4th to 5th and "brush" her leg on the way.
It works, and is UBER smooth.
Zane
2007 Titanium 4x4 AT
Convenience Package, Upgrade #2
275/70 MT/R's, ARB, Warn M8000, 2.5' front leveling spacers, IPF 968's, original cut-hack, TRD sliders, Cobra 75WXST w/ Firestick, dbbd1's hi lift brackets & hi lift, K&N drop in
