Old 10-30-2007, 01:47 PM   #1 (permalink)
jferg's Avatar
Member Number: 3906
Removal of Contact Cement on Dash
I have some contact cement residue left on the plastic of my dash. Other than rubbing it off with your finger does anyone know how to remove it?
Thanks.
jferg is offline
Old 10-30-2007, 03:11 PM   #2 (permalink)
Steve_53's Avatar
Member Number: 9264
Re: Removal of Contact Cement on Dash
I'd go with the finger, any solvent that will remove contact cement would likely eat the dashboard....
Steve
2007 FJ: Titanium, 6MT, CQ, GY, UP1, C7, Z1. K&N Air Filter, Westin Nerf Bars, Stebel Air Horn, In-Channel Vent Visors, Parrot CK-3100 Bluetooth, Hardwired Radar Detector, Toyota/Garmin GPS, SAS fog lamp kit, Custom shift knobs, ATRAC Hack, SAS GM map light, Heated Multivex mirrors, Running light+turn signal mirror lamp mod, ScanGauge II, 200 PSI on-board air system, Siege Engineering Hammer 4 air horns, rack-mounted halogen back-up lights, VR3 backup camera.
Steve_53 is offline
Old 10-30-2007, 03:14 PM   #3 (permalink)
NCFJ's Avatar
Member Number: 8585
Try a good Artgum Eraser, you can get them at any office supply store.
NCFJ is offline
Old 10-30-2007, 03:20 PM   #4 (permalink)
MudLovingFJ's Avatar
Member Number: 8945
Send a message via AIM to MudLovingFJ
maybe use goof-off, but test it on a small inconspicuos area first to see how the dash reacts.
The So-Cal Safari Snorkel Install Guy 7 chicken necks installed to date
MudLovingFJ is offline
Old 10-30-2007, 05:16 PM   #5 (permalink)
Nor-CalFJ's Avatar
Member Number: 13795
Yeah go with goo-gone, and test it first on the dash in a non-visible place.
Nor-CalFJ is offline
Old 10-30-2007, 08:30 PM   #6 (permalink)
jferg's Avatar
Member Number: 3906
Thank you to everyone that replied with a suggestion.
jferg is offline
Old 10-30-2007, 09:43 PM   #7 (permalink)
Member Number: 8945
no problem, just let us know what works
Old 10-30-2007, 09:47 PM   #8 (permalink)
Briman42487's Avatar
Member Number: 7204
better thna goof off, try 3m adhesive remover, always test though. it is gentle on most plastic and painted surfaces.
Briman42487 is offline
Old 10-30-2007, 09:48 PM   #9 (permalink)
Member Number: 7204
on a second thought, how did you get contact cement on the dash, and what were you doing?
Old 10-30-2007, 09:56 PM   #10 (permalink)
tcd7362's Avatar
Member Number: 14215
maybe a little rubbing alcohol might work (try it first on inconspicuous place) btw..... how a man gets somthing on his is dash is none of our business ....(i guess)
black cherry
6/mt
a-trac hack
cool stickers
tcd7362 is offline
