Just picked up a 2011 army, 41k. Thought I looked it over pretty good. When I took it to work a co worker and FJ owner asked what happened to my trailer hookup.
I was so focused on the fact that it had a hitch which is what I wanted and missed
that the trailer flat connector was not there.
The dealer tells me I need the complete wiring set up with relay converter ect...
for $95. It looks like to me I only need the 2ft. cable that goes from the connecter at the rear frame to the bracket near the hitch. The bracket is there.
How can I tell if that's all I need?
Of course since the deal is done it's on me.
Most likely someone put on the hitch kit but not the harness kit. It appears that bracket that the harness connects to is part of the hitch kit.
Here is a link to what you need. It also has picks and directions so you can see what you have and what you need.
Parts include the harness, relay, fuse, and converter which connects under the kick panel on the drivers side. 4 Pin Wiring Harness-Trailer Hitch at Sparks Toyota-Scion, Myrtle Beach, SC
I was so focused on the fact that it had a hitch which is what I wanted and missed that the trailer flat connector was not there.
The dealer tells me I need the complete wiring set up with relay converter ect... for $95. It looks like to me I only need the 2ft. cable that goes from the connecter at the rear frame to the bracket near the hitch. The bracket is there. How can I tell if that's all I need? Of course since the deal is done it's on me.
That will give you all the info you need about the hitch wiring kit. Least expensive I've found is on Amazon, for about $85 delivered. It shouldn't take more than about 15 minutes to install it, the most time consuming part is playing contortionist while getting your head down in the driver's footwell so you can mount the "converter module".
Hey kind of in same boat here, but mine was a factory job, the hitch and the four flat where there but the wires from the 4flat are ripped out. Looks like maybe drove over something and ripped it off. Does anyone know where the harness would normally connect too?
Yes, I will try an upload picture tomorrow. It should already have converter somewhere, the mount and the 4 flat is there. There is just the wires where it's been ripped out. So all I see is 4flat with wires coming out and no idea where they would connect
There's a link in post #4 that will take you directly to the installation instructions, which show exactly where the connector on the vehicle harness is. It's on the inner face of the LH frame rail, just in front of the rear most cross member (bumper). Your missing stub harness is only about 18" long. The installation instructions will also provide the part number for the stub harness, hopefully it is available as a replacement part.
Related Threads
Toyota FJ Cruiser Forum
3.7M posts
122.6K members
Since 2005
