Old 11-03-2007, 07:21 PM   #1 (permalink)
carlgcs's Avatar
Member Number: 13261
FJ weight at 4 corners
Installed a 3" lift today with sliders on a stock 07 FJ and weighed it at various stages of the install for the hell of it. Some of you might find it interesting, and some may not. So here it goes.
2007 FJ Cruiser...Conv. package...option #1...Roof rack...Auto tranny...Full tank of gas with less than 1 mile driven to get to shop.
3" lift kit (Toytec with OME 884's up front with 1/2" spacers, and Toytec customs in rear.
All-Pro Sliders
LongAcre Computer scales with printer
STOCK
Total weight...4309lbs
left front........1237
Left rear.........1003
Right front.......1090
Right rear........979
Left................2240 52.0%
Rear...............1982 46.0 %
Cross..............2093 48.6 %
WITH LIFT
Total weight...4322lbs
Left front.......1223
Left rear.........1028
Right front.......1099
Right rear.........972
Left.................2251 52.1%
Rear................2000 46.3 %
Cross...............2127 49.2 %
WITH LIFT & SLIDERS
Total weight....4402
Left front.......1245
Left rear.........1048
Right front.......1116
Right rear.........993
Left.................2293 52.1 %
Rear................2041 46.4 %
Cross...............2164 49.2 %
Well, there it is. Useless info for some, essencial reading for others.
What is it for you??
07 Sun Fusion
A/T, Roof rack, Conv. package
ATRAC, Rear diff lock
3" Toyotec lift, OME 884's up front
& Toytec customs with OME shocks out back
BFG KM2's 285/70/17
Factory steelies
Scuba mod
AFE CAI
AFE 3" High clearance exhaust
All Pro Sliders
Tundra door handles
Cobra 75 WXST CB, Bandi mount & 3' Firestick
48" Hi-Lift jack
Yellow IMP shifter knobs
2 console mounted 12v power ports
7 circuit auxillary fuse box
Garmin c550 GPS with FJC icon
Trail Team Schwag bag filled with stuff
carlgcs is offline
Old 11-03-2007, 07:46 PM   #2 (permalink)
technoreid's Avatar
Member Number: 10602
Re: FJ weight at 4 corners
Cool info!
Is this the MT or Auto?
thanks, techno
carlgcs previously said: View Post
2007 FJ Cruiser...Conv. package...option #1...Roof rack...Full tank of gas with less than 1 mile driven to get to shop.
All-Pro Sliders
STOCK
WITH LIFT
WITH LIFT & SLIDERS
technoreid is offline
Old 11-03-2007, 07:52 PM   #3 (permalink)
carlgcs's Avatar
It's an Automatic Tranny, will add it to post.
Thanks for pointing that out!
07 Sun Fusion
BFG KM2's 285/70/17
Factory steelies
Scuba mod
AFE CAI
All Pro Sliders
Tundra door handles
48" Hi-Lift jack
carlgcs is offline
Old 11-03-2007, 07:56 PM   #4 (permalink)
technoreid's Avatar
No problem! How did you weight it? I mean was it like on of those weight machines I see at the garbage dumps?
I find all this info interesting.
thanks, tchno
Old 11-03-2007, 08:14 PM   #5 (permalink)
carlgcs's Avatar
technoreid previously said: View Post
thanks, tchno
It's a pretty high tech unit used to weigh race cars for various reasons.
It's consists of a computer unit with 4 aluminum "pads" that are about 18"x18"x4" they all connect to the computer and weigh each corner of the vehicle as well as calculating %'s of weight through out the vehicle.
You can see more about them at their web site
Longacre Racing Online
07 Sun Fusion
BFG KM2's 285/70/17
Factory steelies
Scuba mod
AFE CAI
All Pro Sliders
Tundra door handles
48" Hi-Lift jack
carlgcs is offline
Old 11-04-2007, 08:31 AM   #6 (permalink)
Member Number: 14403
Thanks for the info. I really appreciated it! It is interesting to see the weight bias in the FJ. I am really curious as to why they put the gas tank onto one side.
Those weight scales come in handy in setting up racecars going on the track.
JData is offline
Old 11-04-2007, 08:34 AM   #7 (permalink)
johnnewyork's Avatar
Member Number: 12032
very helpfull wish you posted it 3 months ago but thanks
http://fjcruisernortheastrun.org/
THE DEAL warn9.5,custom bummpers/sliders
2500watt inverter CB,Pioneer dvd nav deck JL audio all around .SFA Spidertrack 9"front housing 31 splin inner outer axels/radius arms. Arb locker/compressor/onbord air
Allpro/Walkerevans 4"to 7 1/2"adjustable front coilovers 5" roughcontry rear coils/ track bar. 3"custom pucks rear .8"lift all together Yukon 488 front/rear Allied beadlocks 15" Parnelli Jones dirt grip 38".Recovery gear tools rear draw system.
johnnewyork is offline
Old 11-04-2007, 10:16 AM   #8 (permalink)
carlgcs's Avatar
JData previously said: View Post
By leveling the truck with the 3" lift you remove weight from the front and place it at the rear. In theory this may increase rear traction some.
07 Sun Fusion
BFG KM2's 285/70/17
Factory steelies
Scuba mod
AFE CAI
All Pro Sliders
Tundra door handles
48" Hi-Lift jack
carlgcs is offline
Old 11-04-2007, 11:01 AM   #9 (permalink)
luigi3's Avatar
Member Number: 8535
Was there a driver inside at the time of weighing or is it the full gas tank that's adding 200+ lbs on the left front corner?
I may have spoken a little too soon... I'm guessing a full tank would only amount to somewhere between 100-150 lbs, and I just noticed the difference between left & right front was only about 120-140 lbs... conclusion: no driver, right?
Last edited by luigi3 : 11-04-2007 at 12:50 PM. Reason: didn't think through the first time
luigi3 is offline
Old 11-04-2007, 11:56 AM   #10 (permalink)
5280FJ's Avatar
Member Number: 7663
luigi3 previously said: View Post
X2 on the driver weight. Hopefully that was how the measurements were taken, since mine always seems to have a driver in it when going anywhere...
Also, could you please explain what "Cross" means... Thanks.
EDIT: BTW awesome data!! Thanks. Now I just need to find out where the actual COG is (height wise, toyota shows it in two dimensions of the ground plane)
5280FJ is offline
