Old 02-02-2008, 10:19 AM   #41 (permalink)
FJVP's Avatar
Member Number: 8952
Re: Where do you mount your hi-lift?
slither430 previously said: View Post
I just picked up four. Can't beat that price. Now for the Hi-Lift. 48" or 60"? Help me out my brothers. Got to be ready for Rauscsh Creek in March.
I have the 48".
Tim
FJVP is offline
Old 02-02-2008, 04:00 PM   #42 (permalink)
Everything In Moderation
Landrover's Avatar
Member Number: 772
If you're lifted at all, or plan to lift, go ahead and get the 60", you'll need it.
VOODOO BLUE - 4X4 - AT - CQ - UP2 - ROOF RACK - TOYOTA AIR DAM W/HELLAS - BFG AT's - DEMMELLO SLIDERS
TLCA Member
"Strive for perfection in everything.
Take the best that exists and make it better.
If it doesn't exist, create it.
Accept nothing nearly right or good enough"
Sir Henry Royce.
Landrover is offline
Old 02-02-2008, 05:04 PM   #43 (permalink)
Member Number: 17425
Don't forget the airbag jacks. Works great, very light, takes limited of space, works good on soft surfaces such as sand, marshland etc. Just store it flat in a bag. Disadvantage is that you need your engine going.
brgds,
Peder
Sweden (EU)
Toyota FJC-RRE (2008) RallyRaid
Toyota HDJ80
Toyota KDJ120 (Prado)
Jaguar XKR Competition
http://www.rallyraid.se
Peder is offline
Old 02-03-2008, 08:10 AM   #44 (permalink)
Landrover's Avatar
Member Number: 772
FJVP previously said: View Post
I just bought 6 of those for various other things I need to mount.....
Could you two post up some pics of those clamps when you get them on. Would really like to see the end result.
Peder previously said: View Post
brgds,
They don't work so good for winching, clamping, or spreading either
TLCA Member
Sir Henry Royce.
Old 04-22-2008, 07:29 PM   #45 (permalink)
Pacific Coast Moderator
uphill's Avatar
Member Number: 10461
Mounted across the OEM rack - forward with FourTreks aluminum mounts. Secured with a cable and 2 heavy duty Kryptonite locks.
"L'audace, L'audace, Toujours l'audace!"
THE SCORPION
véhicule tout terrain scorpion
скорпион сервисное транспортное средство
โตโยต้า จัตุรงค์ ยาง ล้อเลื่อน แมงป่อง
vier Radantrieb vom Straßenfahrzeug Skorpion
automóvil cuatro rueda Escorpión
蠍子, 豐田越野汽車
Нэвтрүүлэгч хилэнцэт хорхой
macchina fuoristrada lo Scorpione
uphill is offline
Old 04-23-2008, 07:42 AM   #46 (permalink)
akoda's Avatar
Member Number: 2092
I mount mine like this FOURTREKS HOME
Mike
Read my F'n blog dammit, I worked hard on it.
VooDoo Blue AT, OME 886/895, Ex One Sliders and BullBar bumper, Superwinch EPi9.0, Budbuilt Skids coming very soon
akoda is offline
Old 04-24-2008, 07:10 PM   #47 (permalink)
VooDoo FJ's Avatar
Member Number: 8218
Ordered Demello mounts last night.
2007 FJ MT6||OME 885/895||Firestone Destination 285's||K&N Air Filter||OEM Rock Rails||All-Pro Extreme LCA's, Trailing Link Skids, High Clearance Exhaust||TRD Quick Shifter||Demello Hi-Lift Mount
TLCA #18077
N.C. Beach Buggy Assoc. #12893
TTORA #13074
NRA #149022131
VooDoo FJ is offline
Old 04-24-2008, 08:30 PM   #48 (permalink)
NRAFJ's Avatar
Member Number: 18501
slither previously said: View Post
Picked up a couple. A little hesitant as I haven't seen any pictures of them actually mounted to a OEM rack, but for the price it's worth the gamble (unless of course the thing fails and comes crashing down) I figure with the right cable lock, you should be able to mitigate against utter catastrophe.
I'll post pictures when I get mine up there.
Ling-Ling's Revenge
NRAFJ is offline
Old 04-28-2008, 07:17 PM   #49 (permalink)
NRAFJ's Avatar
Well, I'm not going to have time for a while to actually mount the jack and take pictures, but here's the next best thing.
...I did attach one of the mounts to my rack by itself and was pleased. It might be my imagination, but I'm thinking my OEM rack tubes might not be perfectly round. The mounts seem to fit horizontally, but not veritcally. Stange. I'm sure I could bolt them down and force them on either way as the difference was slight.
Regarding the quality of the product...this being the only mount I've inspected thus far, I would say they are just fine, particularly for $10 each. You'll notice in the pictures that the powder coat is a little scuffed in one place. Also, one of the two mounts is very slightly misaligned when bolted down (you can't see it with the naked eye, but you can feel it). I'm confident that the aluminum tubes will have adequate flex to accommodate this small imperfection.
Here's a question (2 actually)...how tight do you clamp these down and is there any way to prevent scratching the powder coating on the FJ roof rack when using such mounts?
ID:	22946  where-do-you-mount-your-hi-lift-jack-mount-3-medium-.jpg.JPG
ID:	22947  where-do-you-mount-your-hi-lift-jack-mount-2-medium-.jpg.JPG
Ling-Ling's Revenge
NRAFJ is offline
Old 04-30-2008, 05:40 PM   #50 (permalink)
FJ213's Avatar
Member Number: 17972
Send a message via AIM to FJ213
i just got the same clamps today from ebay..i was very please with the craftmanship..although there is a spot or 2 of the powder coat not pristine..
i showed them to a customer of mine today, he suggested lining the inside with some thin rubber from a tire tube etc...to make a tighter clamp and prevent rubbing..also to put some lubricant on the allen screws to keep them from rusting out..
i ordered 2 more sets...just they looked awesome for the price..
08 TT edition, C7 package, Sirius SAT, MPac Side Rack, Front OEM Brush Guard, Hella 500s w/Cages, Manik Rear TailLight Guards, Black Billet Side Mirror Light Guards, 48" HiLift, Recovery Gear, Cobra LTD25 w/LilWill
FJ213 is offline
