Old 01-14-2008, 05:37 AM   #1 (permalink)
Member Number: 6994
Gear Help!!!!!
I am looking into regearing my FJ. I have 35" Toyo's with a Gibson exhaust, a TRD CAI & JBA headers. I also just had installed a TRD supercharger. My OffRoading is an occasional beach run. With that said I know that All Pro offers a 456 gear package. And also Ringpinion.biz offers a 488 package. AllPro is more money, but that is not the issue. The issue is I know that 488's will give a quicker exceleration but at highway speeds will my RPM'S be way to high. Also if ever I decide to sell the truck and want to put the stock tires back on, with 488 gears will the truck be driveable at highway speeds. I don't want it to sound like I am driving 60 in second gear.
pgaups is offline
Old 01-14-2008, 06:11 AM   #2 (permalink)
RomaBoy's Avatar
Member Number: 2866
Re: Gear Help!!!!!
488 gears will be like driving in second gear on the highway...been there, done that...don't do it.
RomaBoy is offline
Old 01-14-2008, 07:43 AM   #3 (permalink)
sbechtold's Avatar
Member Number: 639
Re: Gear Help!!!!!
Stock gearing:
32" tires + 3.73's @ 75mph = 2135 rpm's
35" tires + 3.73's @ 75mph = 1928 rpm's (207 rpm's lower then 3.73 gearing)
4.88 gearing:
32" tires + 4.88's @ 75mph = 2808 rpm's (673 rpm's higher then 3.73 gearing)
35" tires + 4.88's @ 75mph = 2529 rpm's (394 rpm's higher then 3.73 gearing)
I run 4.88's with 35s and I like it. I would not want to run a 32" tire (stock size) on my FJC with the 4.88s.
Member: TLCA / BRC / CA4WDC
sbechtold is offline
Old 01-15-2008, 01:27 PM   #4 (permalink)
DEWFPO's Avatar
Member Number: 7505
Re: Gear Help!!!!!
If your not re-gearing for rock crawling, then your probably re-gearing to compensate for larger tires. The gear ratio, is often chosen to keep the engine in the same rpm band at the same speed as before. So, if the gears are chosen correctly (and they are available), you should be at about the same rpm at the same speed as before (with a corrected speedometer). In a perfect world that is.
So 4.13:1 gears should cause you to run the same rpms with the 35's as with the 32's. But I don't know of any that are available.
DEWFPO
"Enjoying the Journey"
DEWFPO is offline
Old 01-16-2008, 07:27 AM   #5 (permalink)
WyoOtto's Avatar
Member Number: 11698
Re: Gear Help!!!!!
DEWFPO previously said: View Post
DEWFPO
Yea,
This is intriguing to me. If my calculations are correct (and often they are not), you would need a 38.6" tire to maintain the stock effective ratio with a 4.56 gears (the smallest aftermarket ratio available that I'm aware of). I haven't looked into it but someone has to be machining 4.10 gears for these rigs. If they're not, they should be....
Painted headlight bezel, Series 87 steelies with 255/85-16 Maxxis Bighorns, ARB full length rack, 60" hi-lift, OME Heavies on all 4 corners, Budbuilts front to back, OEM sliders, Upper and Lower rear Digger Links, TRD CAI, All-Pro High Clearance tailpipe, Hacked Rear Diff Lock, VSC on-off switch, Custom Expedition One Front Bumper, EPi 9000lb winch with synthetic line, and lots of manual recovery gear and tools.
WyoOtto is offline
Old 01-22-2008, 11:48 AM   #6 (permalink)
ringpinion.biz's Avatar
Member Number: 15208
Re: Gear Help!!!!!
4.88 with a 35" tire is a perfect combo. Your RPM's are plenty reasonable at highway speed, and your performance will be excellent. We HAVE EXPERIENCE with gearing and 4.88 with a 35" tire and an overdriven top gear (wether at or mt) equates to decent RPM. We hear this on any newer vehicle. People are afraid to change gear ratio at first, fearing lost highway driveability. This is just not the case. In a couple years 4.88 will be the norm for 33s & 35s. This happens any time a vehicle comes out. On a forum you get the guys that say they run 35's with stock gears and get 20 mpg, etc, etc. You gotta remember we are basing this off real experience of hundreds if not thousands of vehicles over several years time, while the average forum guy is basing it off of his own single truck with no basis of comparison. Take it from sbechtold, he's got 4.88 and likes it. I do agree, 4.88 with stock tires is too low.
sbechtold previously said: View Post
Stock gearing:
4.88 gearing:
JTS PARTS & ACCESSORIES
SPECIALIZING IN DIFFERENTIALS AND 4X4s
Nitro Gear 4.56T & 4.88 gears now in stock for FJC!
509-888-AXLE (2953)
info@justdifferentials.com
www.justdifferentials.com
ringpinion.biz is offline
Old 01-22-2008, 12:17 PM   #7 (permalink)
Briman42487's Avatar
Member Number: 7204
Re: Gear Help!!!!!
if you are just doing highway driving and you are supercharged, 4.56's would be plenty. if you are into crawling, look at the best pinion gear set to get you down the highway, then get the most gearing at the t-case.
Briman42487 is online now
Old 01-22-2008, 01:23 PM   #8 (permalink)
DEWFPO's Avatar
Member Number: 7505
Re: Gear Help!!!!!
With all due respect to your experience ringpinion.biz. The stock tires are 31.6" in diameter. I can't see how going to a 33" tire would make going from the stock 3.73's to 4.88's a normal event.....? The tires increase in size by only 4.4%, the gear ratio would increase by 30.8%. If you're just trying to correct for larger tires, that just doest't make any sense to me, at all.
DEWFPO
DEWFPO is offline
Old 03-22-2008, 12:33 AM   #9 (permalink)
DC Cruiser's Avatar
Member Number: 13963
Re: Gear Help!!!!!
I agree. I am going to be putting on 34's and a 4:10 ratio sounds perfect. IMHO
GRAMPS TOY: 07 BD "C" Package, 5Spd Auto, Hood Deflector, Vent Shades, Pass. ArmRst, SS Grille Inserts, Black Tundra Handles
OFF ROAD MODS: ARB Winch Bumper, KC Daylighters, PIAA 510 Fogs, K&N Filter, 12,000 lb. Titan Winch w/syn line, SAW Hybrid Suspension (Metal Tech) Rasta 4x4 Ally skids, Pro-Comp 7028's (powdercoated white) & Goodyear 305 x 17 MT/R's, SpyderTrax Spacers.
FUTURE MODS:Rear Bumper, Aux Gas Tank, TRD SC,
ORIGINAL FJ:71 FJ4030 yrs ago) 350 Chevy V8 Conv., 4Spd GMC Truck Tranny, (IT BURNTUP)
DC Cruiser is online now
Old 05-12-2008, 03:51 AM   #10 (permalink)
SKINUM's Avatar
Member Number: 18535
Re: Gear Help!!!!!
So, does the size of the tire alone warrant regearing? A 33 inch tire comes in different weights. So, for instance if you go with a 33x10.50 in comparison to a 33x12.50 the 10.50 is going to be less weight. Does the overall height change the revolutions of the tire which would cause a gearing issue or does the weight cause this issue? I guess it could be combined.
To me it seems that if your overall weight increases by 3-4lbs per tire over stock then regearing isn't really needed.
For instance a 255/85/16 tire: weight 53lbs Rim width 7in rpm's 625 33.3
265/75/16 tire: weight 51lbs Rim width 7.5 rpm's 652 31.9
Net difference 1.4 and 8lb increase
Seems to me your decreasing your rpm's by the increase in tire height then a increase in weight. So, the rpm's run lower with only a increase in weight of 8lbs. To me this combination would seem to give the advantage of clearance and no real reduction in torque or gas mileage.
However, if you go with a 35 then your total weight of each tire is 64lbs. So, your total weight increase is 52lbs. and rpm's drop to 598. 31.9 stock and 34.8 =2.9 difference. In this case it seems that rpm's decrease more because of the additional weight rather then height.
With my reasoning it seems that with the 33 inch option there would be no real disadvantage. Actually, with the added height, less rpm's and a increase of only 8lbs to me it would seem more advantageous.
So what am I missing?
SKINUM= Redskins fan not a taxidermist.
**2007 alloy used as spare make a offer.**
SKINUM is offline
