Old 03-20-2008, 05:04 PM   #1 (permalink)
Member Number: 18417
Battery and lighting questions
I'm new to the forum and I just picked up a trails team edition and want to begin by adding lights. I've been reading through the many posts on dual battery setups and how to wire the roof lights. My first question is if I need a dual battery setup? I will have (2) Fuego HID's and (4) Fuego halogens. Is this going to cause problems with the stock battery setup? After I finish with this upgrade Ill do the stereo and end up with (2) JL Audio amps. At that point am I drawing to many amps and run the risk of a dead battery or something?
JesseWin26 is offline
Old 03-20-2008, 05:37 PM   #2 (permalink)
Fjamming's Avatar
Member Number: 6623
Re: Battery and lighting questions
Hi Jesse, welcome to the forum. The HIDs are not very taxing on the battery, but the 4 halogens can. What wattage are the halogens and amps?
Sandoo Blue FJ
Walker Evans adj. F&R reservoir shocks. Pro Links. AP F&R bumpers. Demello skid. Mile Marker SE9500C. Viking Trail Line. Super Swamper LTB 34s on Tacoma wheels. Trail Gear Sliders, Aeroflow, Lightforce Blitz 240, Powertank 10lb, Hi-Lift, Jack Mate, Pull-Pal.
SoCal Events Calendar
Fjamming is online now
Old 03-20-2008, 07:00 PM   #3 (permalink)
The halogens are 100 watt.
Old 03-20-2008, 07:03 PM   #4 (permalink)
I have found a couple of links of posts but I need 4 posts before I can link to them...
Old 03-20-2008, 07:03 PM   #5 (permalink)
and I have 4 posts below are the links to the resources I found.
Old 03-20-2008, 07:05 PM   #6 (permalink)
http://i63.photobucket.com/albums/h1...cedDiagram.jpg I would like to wire it right so I get the best performance and have a few spots left to add other lights. Is the above linked picture a good way to wire?
I want to wire the lights like this guy did on his. Roof light wiring, inside OEM rack I like to do things right the first time even if it costs a couple bucks to do it.
Old 03-20-2008, 07:22 PM   #7 (permalink)
Fjamming's Avatar
Member Number: 6623
Jesse, looks like you need dual battery. You'll probably want to add more accessories later anyway. Cruiserlarry is a guru on this. Maybe give him a PM.
Sandoo Blue FJ
Old 03-20-2008, 08:04 PM   #8 (permalink)
NCFJ's Avatar
Member Number: 8585
JesseWin26 previously said: View Post
I am the author of both threads you mentioned. I did the bus bar setup beacuse it was a cleaner way to bring the power from the engine compartment into the interior, in my opinion.
The same wiring setup can be done without the bus bar by simply running the main power leads out to the battery as well. I also chose to put the relays inside to keep them out of the heat and weather under the hood. My way is not the "right" way, just the right way for me. Let me know if there is anything I can help with. Good luck and enjoy the project.
Stan
"Life is a full contact, participation sport. Get in there and play "
I live in typo hell, excuse the typos
My FJ may be new, but this aint my first rodeo
NCFJ is offline
