Old 03-22-2008, 06:48 PM   #1 (permalink)
River Runner's Avatar
Member Number: 8677
Location: somewhwere in the osage on the arkansas river
OK...What New Mig Welder Would You Buy???
Time to up grade...i have a old lincoln 225 cracker box(toast)...looking at a lincoln 180 mig pack....miller140....my budget is around $500 to $850....any advice....i have 220 volt single phase in the shop....but some i have noticed are 110v....i would like to have one i could do body work with...and still be able to weld 1/2 plate????
River Runner is offline
Old 03-22-2008, 07:45 PM   #2 (permalink)
NCFJ's Avatar
Member Number: 8585
Re: OK...What New Mig Welder Would You Buy???
I have the Millermatic 175 22V and am happy with it. DOnt think it will fit your budget though. I'd stick with 220V for sure the 100V's dont have enough snot IMO
Miller Mig Welder
"Life is a full contact, participation sport. Get in there and play "
I live in typo hell, excuse the typos
My FJ may be new, but this aint my first rodeo
NCFJ is online now
Old 03-22-2008, 08:58 PM   #3 (permalink)
scottyms's Avatar
Member Number: 16514
River Runner previously said: View Post
one machine that will do both 20 gage and 1/2 plate isn't gona make your budget, not a good quality machine that will do both well. i would suggest you realy think about what you are going to weld and how often? also whats your experiance level? if you do mostly thiner gage material you can get in to a good quality 120 volt machine easly in that price range. 1/2 plate can be done with a smaller machine in multipul pass's. if you do more heavy 1/4" and up than you realy need the bigger machine. the other thing to consider is the duty cycle, the 110 machines usualy have a low rating, 10 - 20 % is common, this means you can be actualy welding for 1 or 2 minets in a 10 minet time period. the 220 machines are generaly up to 50 or 60 %. if you push the duty cycle you will damage the welder, the diodes will usuly go first wich are easy to replace, but you'll be done welding in mid project untill its repaired.
you cant realy go wrong with any of the big names, i have had Hobart brand equipment for years. hobart and miller are owned by the same parent company and in my opinion are of the same quality, hobart is usualy a little cheaper as miller is there flagship line. if you can afford it ( prob. around a grand ) look at hobarts Ironman 210 it's a good quality machine that will do most of what you want with the ability to add a second plug-in spoolgun in if you ever want or need to do aluminum.
hope this helps if i can give you any other advice let me know. i'm not a professional, i grew up spending my summers with my grandfather who held a certification to do welding on nuclear power plants. he tought me a hell of a lot, i still wish i had paid more attention.
scotty
" It's a semi true story, believie it or not. i made up a few things and there are some i forgot."
'08 Titanium FJ, off road pkg.
3" All-Pro Walker Evans coil overs, Walker Evans rear shocks, All-Pro front UCA's, rear UCA's, rear Pro links, rear springs, sway bar collars, sway bar links.
All-Pro front & rear bumpers
All-Pro Rock sliders
Warn M8000 winch
Bigbill Combo Cobra WX75 cb
URD Y pipe, JBA cat back
ARB Snorkle
scottyms is offline
Old 03-23-2008, 06:32 AM   #4 (permalink)
Member Number: 8677
i am now looking at the miller line up......thanks scotty.....RR
Old 03-23-2008, 07:37 AM   #5 (permalink)
breauxtus's Avatar
Member Number: 10906
I have the Lincoln 175 pak sold at Home Depot. Welds very well both flux core and gas. I use flux core outside and can weld up to 1/2" with a couple of passes and when I'm inside out of the wind, use a gas setup that helps to produce a much finer weld and can weld about 1/4" single pass with a beautiful weld. Welder is about $550, if you already have a tank, you're off and running. Otherwise, buy a filled tank for about $150 and you're set.
Mike
YinYang
2007 FJC
They call me The Threadkiller!
breauxtus is online now
Old 03-23-2008, 10:23 AM   #6 (permalink)
sonof40's Avatar
Member Number: 11473
I have the Lincoln SP-135T. I got it because at the time I thought it was the "Cadillac" of welders. Turns out it's only the "Lincoln" of welders.
(but it's served me well so I'll keep it)
Steve
TLCA #14294
FJC Mods: (15 and counting)
Sleeping/Storage build: http://tinyurl.com/367bbw
CB: Cobra 75 / Bandi http://picasaweb.google.com/steven4m/CBInstall
Back Door Inside Latch: http://tinyurl.com/2jxwkk
FJ40 Restore:
http://globalsoftware-inc.com/stevesfj/1.htm
sonof40 is offline
Old 03-25-2008, 02:44 PM   #7 (permalink)
jorge's Avatar
Member Number: 6927
hello
I also have the Millermatic 175 230volt with the carbon dioxide bottle attachment. Makes for a good clean weld.
jorge is offline
Old 03-26-2008, 12:10 PM   #8 (permalink)
jamesart86's Avatar
Member Number: 17436
I've got a Hobart 250 ironman, the big one. I think it was about $1300 or so. Northern Tool had a deal that you could make like 4 credit card payments. SOmething to consider. It'll pretty much weld anything you'd ever want to build (sheetmetal, framework, aircraft carrier.....). Miller does own hobart and they share many components, but the hobart does use a few parts that are cheaper quality (I think the spool drive is plastic compared to metal in the miller) but it is all in parts that usually don't break anyway (electronics are the same). If you are buying for heaVy, constant industrial use, get miller, for light industrial or home, save the money and go hobart. And get 220. You'll never regret buying too much welder, but I know you'll regret buying to small of one.
08' Sandstorm 6mt FJ blacked out with 3" OME lift, BFG m/t KM2's, All Pro front bumper and skid, smittybilt winch, homemade sliders, homemade skids, trail damaged rear bumper.
07' Kawasaki Ninja zx-6r
73' VW Thing
jamesart86 is offline
Old 03-26-2008, 12:18 PM   #9 (permalink)
bartt's Avatar
Member Number: 1660
NCFJ previously said: View Post
Miller Mig Welder
You might be surprised. I got my 175 online from a great dealer and had it shipped here for about $650 total.
You're right about 220v, use it if you have it.. 110V can't deliver the current for anything very thick.
HTH..
07 Titanium loaded..
Current mods: OME883's & Bilstein513's, BFG KM2's, Bridgestone Revos, Trailgear Sliders, K&N Drop in, 08 side visors, 35% tint, Redline gear oil, Atrac hack, mini-ITX PC (GPS & wardriving), upgraded speakers, custom rear door sub, custom air dam w/ hella spots and surf rack, grill mounted hella driving and fog lites, air horns, solar batter charger, rear 12V outlet, block heater, painted stock alloys (1 set black, 1 set graphite)..
bartt is offline
Old 03-26-2008, 12:26 PM   #10 (permalink)
East Coast Moderator
Bostonian1976's Avatar
Member Number: 333
River Runner, boy do I have a great project for you to have a little 'fun' with your new welder...
MT6 Titanium
Wanting TRD wheels
'67 Land Rover Series IIa
Speed Demon!
' 65 Land Rover Series IIa
Bostonian1976 is offline
