Old 03-25-2008, 08:02 AM   #1 (permalink)
nightster 13's Avatar
Member Number: 16751
toggling off-road lights??
I travel on many country roads during the night or dusk hours so I am thinking of adding lamps to increase the distance viewing, but also to light up more of the side of the road for the sake of looking for deer. Obviously a lot of roof mounted lamps or off-road lamps are not for street use but the back country of MO and KS where I drive there is rarely law enforcement, much less that would care. My question is this: Are off road lamps not so ideal for switching on and off when there is head-on traffic as a regular highbeam or is it okay to do this as normal?
nightster 13 is offline
Old 03-25-2008, 08:03 PM   #2 (permalink)
Razor J's Avatar
Member Number: 4495
Send a message via MSN to Razor J
Re: toggling off-road lights??
Good question-my PIAA's suggest that you don't turn on/off frequently and I drive as you do--on remote county roads where I need them. I, in fact did not connect mine to the high beam power feed, so they are on or off.
I am not a light guru and would like to get the opinion of those who are.
Good post
Razor J is offline
Old 03-25-2008, 08:06 PM   #3 (permalink)
Fjamming's Avatar
Member Number: 6623
The higher wattage lamps do not like to be turned on and off. The 55Ws might fare better, but you should still avoid frequent on and offs.
Sandoo Blue FJ
SoCal Events Calendar
Fjamming is offline
