Old 03-25-2008, 02:50 PM   #1 (permalink)
layonnn's Avatar
Member Number: 10006
clanking noise, need help.
My set-up i am running is in my signature. This just started yesterday out of the blue (as in no offroading recently or recent installs).
If i am in neutral and shift in to reverse and start to move, i hear a clank. if i stop. and then put in D and go forward, i hear another clank. As if something is moving when i change directions. It is definitely coming from the front of the vehicle. I checked the winch and the bumper and that all seems fine. Maybe sway bar or something???
Any one ran into this issue before and have an idea?
Layton
2007 FJ Cruiser 5AT 4x4
Voodoo Blue
"God forgives...rocks don't"
layonnn is offline
Old 03-25-2008, 02:58 PM   #2 (permalink)
East Coast Moderator
Bostonian1976's Avatar
Member Number: 333
Re: clanking noise, need help.
Clank Clank Clank Rattle Rattle (Please help me determine what is doing this)
by the way I still haven't fixed mine (never drive it anymore anyway)
MT6 Titanium
Wanting TRD wheels
'67 Land Rover Series IIa
Speed Demon!
' 65 Land Rover Series IIa
Bostonian1976 is offline
Old 03-25-2008, 03:08 PM   #3 (permalink)
toddunderscore's Avatar
Member Number: 9930
I figured out that alot of the clanking on my vehicle was from the trailing link skids from AllPro. If you don't have them tightened enough, they'll tilt back and forth when the rear suspension drops even the slightest. Easy fix. Though it did sound like the back end was about to hit the ground...
"I'd like to die in my sleep like my grandfather. Not screaming in terror like the passengers in his car."
TreadLightly — member
Expeditioneers.com
toddunderscore is offline
Old 03-25-2008, 03:11 PM   #4 (permalink)
Member Number: 11817
Send a message via Yahoo to ziggzaggman
Sounds like u-joints to me from what you describe.
ziggzaggman is offline
Old 03-25-2008, 03:16 PM   #5 (permalink)
layonnn's Avatar
toddunderscore previously said: View Post
i don't have that product though,
I just checked the entire back end, drive shaft, shocks, and exhaust system, now i am about to go check and wiggle as much of the front as i can.
Once again, it's coming from the front ( i think) and it is ONLY when i change direction from forward to reverse, or reverse to forward.
Layton
Voodoo Blue
layonnn is offline
Old 03-25-2008, 03:17 PM   #6 (permalink)
layonnn's Avatar
ziggzaggman previously said: View Post
I know, i just checked them. Is there any other way to check them then to grab them and see if they have any give???
That was the method i used on my CJ-7.
Layton
Voodoo Blue
layonnn is offline
Old 03-25-2008, 03:20 PM   #7 (permalink)
Shake them up and down and you should feel some slack, it could aslo be slack in your front diff.
Old 03-25-2008, 03:23 PM   #8 (permalink)
If there are grease nips shoot some in there and see if the noise changes, not a fix but a diagnostic tool.
Old 03-25-2008, 03:34 PM   #9 (permalink)
layonnn's Avatar
Okay skid plates are off. I was thinking the sway bar was maybe hitting something but that doesn't seem to be it either. Man. the search continues. I am going to go grease it up right now.
Layton
Voodoo Blue
layonnn is offline
Old 03-25-2008, 03:54 PM   #10 (permalink)
layonnn's Avatar
Okay, ive managed to isolate the sound to an exact instance
If i put it into reverse, and take off it is when i apply the brakes. Like something is shifting.
When i take off in drive and then apply the brakes, it makes the exact same noise, like something is being shifted forward.
Layton
Voodoo Blue
layonnn is offline
