Old 03-26-2008, 09:19 PM   #1 (permalink)
dre748's Avatar
Member Number: 14237
Question URD short throw shifter????
anybody have one and how would u rate it?
dre748 is offline
Old 03-26-2008, 09:28 PM   #2 (permalink)
crestwood36's Avatar
Member Number: 17104
Send a message via AIM to crestwood36
Re: URD short throw shifter????
I put mine in about 3-4 weeks ago. Very worth it. If you put one in, be sure to use a weighted shift knob or reverse will be a real pain. Anything from TWM is a great compliment to the URD kit.
"The ultimate goal of the educational system is to shift to the individual the burden of pursing his own education. This will not be a widely shared pursuit until we get over our odd conviction that education is what goes on in school buildings and nowhere else."
John W. Gardner
crestwood36 is offline
Old 03-26-2008, 09:48 PM   #3 (permalink)
kmv416's Avatar
Member Number: 11236
I installed mine about six months ago and like it a lot compared to the long throw of the stock shifter. I have the stock shift knob, and reverse is a little tricky, you have to rock it into place while applying a good amount of pressure. Maybe I will have to try a heavy shift knob and see how that works?
2007 TITANIUM METALLIC 4X4 6MT
ROCK RAILS/PAINTED SPARE TIRE COVER/A-TRAC SWITCH/TOYTEC FJ3-FRCC LIFT/MICKEY THOMPSON 265/70R 17 BAJA MTZ TIRES/FLOWMASTER 40 SERIES MUFFLER/AFE COLD AIR INTAKE/ELLIS BATTERY CLAMP/ALL PRO IFS & TRANSMISSION SKID/URD SHORT SHIFTER/ELLIS DOM MOUNTS/LUCRUM WINCH MOUNT/MILEMARKER SI9500
I will soon be off again...The mountains are calling, and I must go.
kmv416 is offline
Old 03-27-2008, 10:21 AM   #4 (permalink)
Toledo FJ's Avatar
Member Number: 14676
I've had mine for a few months and I love it. If you guys are having difficulty getting into reverse, it isn't properly installed. It should be a little more stiff than stock, but not much. I had the same problem. It was so hard I had to use two hands to get into reverse. I called URD and they said it wasn't installed correctly. They were right. Now reverse is easy with one hand. I rate the product very highly. I also agree that a weighted shift knob is a great addition. TWM Performance makes some of the best.
Toledo FJ is offline
Old 03-27-2008, 10:39 AM   #5 (permalink)
FJ FunJunkie's Avatar
Member Number: 7470
wanted this for a while now, anyone have the info to buy one? website link?
I'm a pretty straightforward guy as long as I'm not BS'n ya
FJ FunJunkie is online now
Old 03-27-2008, 10:43 AM   #6 (permalink)
URD Short Shifter Underdog Racing Development
TWM Knobs
Shift Knobs by TWM Performance Shift Knobs
I love my bombshell in gun metal
John W. Gardner
Old 03-27-2008, 01:08 PM   #7 (permalink)
Toledo FJ's Avatar
I have the .44Mag on the stick and the M1 Abrams on the T-case. Both with the satin finish and the black bolts in the Magnum. Absolutely love them.
Old 06-05-2008, 12:06 PM   #8 (permalink)
NUTTYFJ's Avatar
Member Number: 9869
Toledo FJ previously said: View Post
I read this thread before installing my URD short throw and made sure that the shift extension was seated properly....reverse is a real pain in the ars. I am curious as to what you did to correct this?
BD/ 6MT/ URD Short-throw / RC 3''/ 34 X 10.5 X 17 LTB's/ 17 X 9 AR Teflon Dominators/ Hella 500's/ Blackout bumps/ A-Trac...
NUTTYFJ is offline
Old 06-05-2008, 12:55 PM   #9 (permalink)
Savvyav's Avatar
Member Number: 2188
Year and a half and no issues!
Maybe you should work out a bit =)
AKA Thread Killer I post and bore threads to DEATH. Ninja poster, like I was never there.....
The Flying Pig BD, MT
Mods: REALLY nice tire stem covers
Savvyav is offline
Old 06-05-2008, 01:04 PM   #10 (permalink)
Part of this has to do with the loss of leverage you get by extending the stem. By doing this you are moving the distance of the fulcrum (pivot point of the shifter) away from the load (transfer case), which results in more force required to change gears.
The reason many of us use a weighted shift knob is to counter this loss in leverage. The momentum gained by adding weight reduces the force required to shift.
And you thought physics was just for figuring out if a bowling ball or golf ball would hit first if dropped from the same height
John W. Gardner
