Just wanted to give everyone a heads up. I just changed out my cabin filter, and it was extremely dirty. I've had my FJ for about 14 months, and put 12,500 miles on it. I use my FJ daily, and I don't consider my use severe, really not in dusty conditions. I was doing an oil, and filter change, engine air filter, wipers, and figured I'd do the cabin filter aswell. I never would have thought it would be that dirty! It was worse then the engine air filter. To change it out was very easy. Just remove your glove box, and the filter is directly behind it in a white housing. 2 tabs have to be pushed in and the filter pulls out. I would suggest this being changed once a year. It might have been posted before but I think its a good reminder.
part number: 87139-47010-83
Current Lineup:
'07 Voodoo blue, auto, conv. and upgrade 1 pkg's, & roof rack.
Mod list: TRD Rock rails, Manik front brush guard w/ 2 Hella 500 fog lights, tail light guards, light bar w/ 4 Hella 500 driving lights, AVIC-D3, OME lift, TC UCA's, 285/70 Firestone Destinations.
'07 Porsche Carrera S
'91 Chevy Corvette vert.
Sold- '06 BMW M3 w/ comp pkg., SMG, Fully loaded
Sold- '93 Ford Mustang vert. Feature car
I have had mine for a couple months now and pulled out the filter yesterday and it is already dirty. I think one problem is that it is horizontal and stuff just falls in on top of it.
2008 6MT Sandstorm Convenience package and Offroad package, black tundra door handles, black mirrors, tow hitch,SCUBA MOD DONE..
I just cleaned mine today for the second time in 27K miles. It was fairly dirty, the filter is really thin, almost like tissue and it really should not cost more than $1 or $2. The filter material can easily be removed from the housing, I think I'll cut up a furnace filter I have laying around and use that, I can probably get 10 replacements for under $10 with that.
Voodoo Blue 4X4 with AT.
Added: Warn M8000, Factory rack, Factory hitch, Toytec lift (FJ3-FRCC), Amp-Fortyone-2 Black Alloy wheels with Nitto Terra Grappler 295/70/17, Cobra 75 WXST, Square Sliders, roof rack light bar with 4 Pro Comp lights, 2 Pro Comp lights on custom tube bumper, FJ battery clamp (Thanx Noisycow).
DIY Projects completed:
Toytec lift install, Sliders, body mount chop,Bandi Mount,hitch & tow ring, roof rack light bar and LCNW style bumper.
I remove mine every month or so and vacuum it. I also cut up furnace filters to use as cabin filters. I get a lot of teasing at the Priuschat forum for doing this, but I'm a cheap bastard
I use the Canadian Tire "Supreme" furnace filter. As no actual employee of the doofus Canadian Tire chain actually touches my vehicle, that is ok. The Supreme filter is rated MERV 12 and has a carbon charcoal prefilter
The filter costs $20 and I can easily get six cabin filters out of it. The Prius and FJ cabin filter are close enough in size
As I run in the desert all the time, I clean mine after every run. And it always needs it. When in dust, the recirc is always on so all air passes through it all the time.
'07 Sun Fusion, IPF lights, Bandi mount,4' Fire Stik, Cobra 75 WXST, Garmin 76csx, 2 Blitz roof mounted gas can carriers, Trail-Gear rock rails, Swiss Mini-Consule light, custom laptop mount, customized accessory roof rack and dog in back seat
I don't think I'm rolling in cash, but I actually swap out the filter after every desert run (or so). The air smells cleaner and there is particulate that remains when you knock it out or vacuum it.
It needs attention even if you're doing city driving because it gets dirty.
__________________ "L'audace, L'audace, Toujours l'audace!"
THE SCORPION véhicule tout terrain scorpion
скорпион сервисное транспортное средство
โตโยต้า จัตุรงค์ ยาง ล้อเลื่อน แมงป่อง
vier Radantrieb vom Straßenfahrzeug Skorpion
automóvil cuatro rueda Escorpión
蠍子, 豐田越野汽車
Нэвтрүүлэгч хилэнцэт хорхой
macchina fuoristrada lo Scorpione
