Re: Load resistor, Eletronic Flasher ???
If you just want to go with the resistor you need to just add a resistor in line with the LED that is approximately the same resistance as the stock bulb. In the stock set up the bulb is a part of the flasher circuit, if you increase the resistance you will slow the flashing and if you decrease the resistance (ie. change to LED) you will increase the flashing speed.
2008 6MT Sandstorm Convenience package and Offroad package, black tundra door handles, black mirrors, tow hitch,SCUBA MOD DONE..
