Old 04-15-2008, 11:17 PM   #1 (permalink)
Member Number: 16557
Winch control box location?
I recently installed a warn winch in a Lucrum mount but have a bit of a problem. I do not want to mount the control box on the outside of the vehilce and want to put it under the hood. The problem with this is that the cables are all of about 12" and do not realy reach from under the hood out to the winch.
So, can I just replace the winch wires with battery cable wires from the auto parts store? If so will it hurt if the cables are 4 ga instead of 2 ga? All I seem to be able to find is 4 ga cables.
Thanks for any help.
2007 Black Diamond AT 4wd
Rear Locker hack
SCUBA diver mod
Tse Gee La is offline
Old 04-15-2008, 11:24 PM   #2 (permalink)
Custom User Title
DominicG's Avatar
Member Number: 1647
Re: Winch control box location?
An idea: Mine is still in the bumper, on top of the winch. I have to open the hood and reach down in between the grill and radiator to plug it in I'm quite sloppy with wiring so it was my best choice.
(u can see the base of the control box on the left top side of the winch.)
DominicG is offline
Old 04-15-2008, 11:39 PM   #3 (permalink)
FJ FunJunkie's Avatar
Member Number: 7470
check around online or mabey harbor freight or any marine supply, definitly dont go down gauge on your power wire, bad juju.
I'm a pretty straightforward guy as long as I'm not BS'n ya
FJ FunJunkie is offline
Old 04-16-2008, 04:27 AM   #4 (permalink)
The Laughing Moderator
LandCruiserSteve's Avatar
Member Number: 8627
I bought three 4' lengths of 2AWG battery cable from a marine/boat supply store.
Like FunJunkie advised, do not go to a smaller gauge wire.
Steve
The '07 Kiroi Hako
'59 FJ25
'78 FJ40
TLCA #6727
UFWDA
LandCruiserSteve is offline
Old 04-16-2008, 06:17 AM   #5 (permalink)
Apexbasher's Avatar
Member Number: 8968
PM Jasim84 for some pictures of his setup. When we did his Lucrum bumper and winch installation we put the control box right next to the winch in the bumper's tray and then removed to plug from the control box cover and mounted it into the front of the bumper on the driver's side. Nice and clean. Some custum battery cables were needed. Most auto parts stores sell 2ga wire by the foot (from a spool in the back, $1.80 a foot here) and the fittings for the ends should be off the shelf.
-Matt
2007 AT 4x4 Voodoo Blue FJ, ARB Bumper, Tabor 9K winch, IPF lights,
ProComp 87 Black Steelies, Nitto Terra Grappler 305/70-16, OEM rock
rails, ToyTec 3" Lift w/ OME 885 springs and ProComp rear shocks,
AVN5500 Nav, Dome/Map lights, Mirror turn signals, HomeLink, Uniden
PC68XL CB, Painless dual-battery, aux camp lighting, bottle opener,
and MUCH trail pin-striping
-Gen. Colin Powell (Ret)
Apexbasher is offline
Old 04-16-2008, 06:32 AM   #6 (permalink)
NCFJ's Avatar
Member Number: 8585
You can also get 2 gauge wire at a welding supply store. Warn also sells it seperate.
"Life is a full contact, participation sport. Get in there and play "
I live in typo hell, excuse the typos
My FJ may be new, but this aint my first rodeo
NCFJ is online now
Old 05-10-2008, 09:32 AM   #7 (permalink)
NRAFJ's Avatar
Member Number: 18501
Apexbasher previously said: View Post
I like the idea of moving the plug from the control box to somewhere more convenient. I've seen one post linking over to a Tacoma (if I remember correctly) forum where the plug was actually mounted inside the cab. Does anyone see a problem with that? I'm planning to add the WARN Power Cut-off kit, so I'm not overly concerned about someone tampering with my winch from the control box plug...but for convenience, seems like having the plug in the cab would be nice. Assuming the control box will be under the hood, then you don't have the remote wire running out from under the hood when winching ...looking for comments on this from experienced 'winchers'. Control plug in the cab or sticking out of the grill???
Ling-Ling's Revenge
NRAFJ is offline
Old 05-10-2008, 06:58 PM   #8 (permalink)
Member Number: 8627
NRAFJ previously said: View Post
Experienced winchers will tell you that the hood should be completely open (for obvious safety reasons) during winch operations. So, having the remote cable running out out the engine compartment shouldn't be an issue at all.
Steve
The '07 Kiroi Hako
'59 FJ25
'78 FJ40
TLCA #6727
UFWDA
Old 05-10-2008, 07:01 PM   #9 (permalink)
5280FJ's Avatar
Member Number: 7663
DominicG previously said: View Post
Dom,
Would you like a fairlead? I have an unused Warn roller one for shipping cost...
5280FJ is offline
