Old 05-02-2008, 05:47 PM   #11 (permalink)
1983FJ60's Avatar
Member Number: 2652
Re: Sueaky clutch pedal?
you're not the only one, but you're the only one who cares:P
mine squeaks, and i just ignore it.
stereo's usually too loud to hear it, anyways.
i was once a rich man. spent my fortune on whores and drink.
1983FJ60 is offline
Old 05-05-2008, 01:34 PM   #12 (permalink)
FJ FunJunkie's Avatar
Member Number: 7470
White Rim previously said: View Post
this is a slave cylinder story , not a master cyl one
but anyway
back in the Old Days, I had to hone out my FJ40 clutch slavecylinder every couple years or so because water would get in behind the piston, causing rust and leaks
THen I got the idea to try something: After honing and peening the cylinder bore once again, and putting everything back together, I put grease behind the piston to coat the cylinder walls and keep water away from them.
That was in 1988, and I have had no more problems with the clutch on the FJ 40.
Now when I got the FJC, there was some chatter in the clutch slave piston so I got some moly disuflide lithium graphite grease, and, using a hypo, gave a few squirts behind the clutch slave piston, right through the boot. No problems since
I think this was the same problem area of mine. It was the cylender at the foot pedal, it just kept getting louder and louder t othe point of completely annoying, they took it apart supposedly and changed some seals then also mentioned some white grease of some sort. I'm just happy it's gone. I hate rattles and squeaks, just bug the crap out of me. lol I'm gonna be nuts in a few years I'm sure.
Ligten up, it's the internet.
You Should Help Chris Walk
FJ FunJunkie is offline
Old 05-12-2008, 10:02 AM   #13 (permalink)
Doomsday's Avatar
Member Number: 18320
FJ FunJunkie previously said: View Post
I will have to tell them to do that next time I go in for service.
Perfection is when there is nothing left to remove.
Doomsday is offline
Old 05-12-2008, 01:01 PM   #14 (permalink)
logan9967's Avatar
Member Number: 19563
Yeah, i'm so ronery. hehehe
logan9967 is offline
Old 05-12-2008, 01:10 PM   #15 (permalink)
frogeye's Avatar
Member Number: 6849
Mike, please define "Sueaky".
Chris | My FJ El Froggo
www.frogeyesprite.org
Save The Cactus!!!
NObama!
frogeye is offline
Old 05-12-2008, 07:36 PM   #16 (permalink)
Member Number: 7470
Re: Squeaky clutch pedal?
I think I went over this in another thread, As a Pirate I never learned to spell so good. lol
Old 05-12-2008, 07:42 PM   #17 (permalink)
slither's Avatar
Member Number: 5147
My 05' Taco has the same issue. They'll lube it up at the dealer and it comes back eventually. Fj is doing it yet.......
2007 Titanium Metallic and YES I wheel it!
TLCA#16880, Gotham City Land Cruisers, Northeast Crew
RASTA Aluminum Skids
Daily Driver:2005 Toyota Tacoma C cab
slither is online now
Old 05-13-2008, 06:51 AM   #18 (permalink)
Member Number: 16872
there was a recall on that clutch, had the same problem in my 05 tacoma. they should replace it for free.
-fbj-
C.O.R.R.E (Central Off Road Racing Enterprise) Looking for sponsers! CORRETeam@mac.com
www.myspace.com/shorleyfbj
http://gallery.mac.com/shorley13
www.mototrailmaps.com
www.freeridebikeandskate.com
www.justridesports.com
fbj913 is offline
