Winch Control box under hood - Toyota FJ Cruiser Forum
 12Likes
post #1 of 17 (permalink) Old 11-27-2016, 07:14 AM Thread Starter
FlyFishNut's Avatar
Quoted: 15 Post(s)
Anyone relocated the control box under the hood? I was thinking beside the battery on top of that electrical box (where the hood sort of has a cavity). Someone I spoke to said it fit there.
I suppose I'll have to lengthen the cables with 3-4AWG and just connect the two female terminals somehow?
Anyone have some opinions?
FlyFishNut is offline
post #2 of 17 (permalink) Old 11-27-2016, 07:17 AM
Sanderhawk's Avatar
Quoted: 419 Post(s)
Re: Winch Control box under hood
FlyFishNut previously said: View Post
I did. Its on the passenger side fender well. It works great and stay cleaner and dryer. I just bought some 3 and 4 foot cables and hooked it up. Simple to do. I will see if I can find a picture for you
Steve 07 FJ with almost enough mods
Sanderhawk is offline
post #3 of 17 (permalink) Old 11-27-2016, 07:23 AM Thread Starter
FlyFishNut's Avatar
Quoted: 15 Post(s)
Sanderhawk previously said: View Post
Cool - I think that will be my project today. Would like to see a pic if you have it. Thanks!
post #4 of 17 (permalink) Old 11-27-2016, 10:30 AM
Mean Time Moderator
Zero'sFJ's Avatar
Quoted: 645 Post(s)
I've just finished installing mine. The Superwinch box too big and awkward shape so had to use a junction box but other makes it should be easier. I relocated to a bracket I had made with the solenoid on the end of the battery and the cut out to the front. Cables are all about 2m long now to reach.
There are other options but this is the only space I had, having used the fender wall for the split charge relay and solar controller.
2014- FJC Cement "Eddystone" US spec personal import - mods in progress http://www.fjcruiserforums.com/forum...eddystone.html
Zero'sFJ is online now
post #5 of 17 (permalink) Old 11-27-2016, 11:38 AM
Loganbeere's Avatar
Quoted: 414 Post(s)
I did. Should probably use at least 2 awg cable though for that length
I have since moved it to here
It's less messy looking
ToyRig likes this.
2013 Iceberg AT 4x4
Ghost FJ Build
Instagram: loganbeere
Loganbeere is offline
post #6 of 17 (permalink) Old 11-27-2016, 04:42 PM Thread Starter
FlyFishNut's Avatar
Quoted: 15 Post(s)
Thanks for posting pics- looks tight!
Took the Control box cover off, connected longer cables, mounted box and ran the cables to the winch and battery,.... etc and was STILL able to get a Christmas Tree.
I just need to reconnect cables to the winch and wire tie/clean it up. There were some areas where I was worried about rubbing so I took a portion of a Mountain Bike Tube and wire tied it around the cable for extra protection.
I'll post pics when I get it squared away.
MagsCruiser likes this.
post #7 of 17 (permalink) Old 11-27-2016, 05:00 PM
toyo22r's Avatar
Quoted: 15 Post(s)
I relocated mine as well. To the passenger side fender. I used 1awg wire bought in bulk length off eBay (welding cable). Also upgraded the finicky Warn solenoids to a Superwinch solid state contactor.
07 FJ Voodoo Blue (The Nostromo)
TLCA# 18990
KF7QGC
toyo22r is offline
post #8 of 17 (permalink) Old 12-02-2016, 10:28 AM
Sanderhawk's Avatar
Quoted: 419 Post(s)
Oh man I'm sorry I totally got side tracked and forgot to post up a picture. Here it is if your still interested.
Zero'sFJ likes this.
post #9 of 17 (permalink) Old 12-03-2016, 07:06 PM
jameykini's Avatar
Quoted: 30 Post(s)
toyo22r previously said: View Post
I also upgraded my Engo solenoids to a Superwinch/Albright solid state contactor when I installed my bumper and winch a few years ago. Mounted the plug-in next to radiator and the contactor next to 2nd battery on the Dirty Deeds battery frame.
Got to give props to Snake Eater: https://forum.ih8mud.com/threads/sup...tactor.767175/ for doing the homework..
Aloha, J.
ID:	809002   Click image for larger version
jameykini is offline
post #10 of 17 (permalink) Old 12-03-2016, 07:48 PM
KB2012's Avatar
Quoted: 8 Post(s)
Here's mine
slymoan likes this.
KB2012 is offline
Human Verification
