Old 05-12-2008, 06:23 PM   #11 (permalink)
layonnn's Avatar
Member Number: 10006
Re: Mounted my HiLift Jack today!!
carlgcs previously said: View Post
That looks great. I am doing the same thing on the passenger side with the same brackets. Let us know if the brackets rotate downwards after hitting some bumps. My idea involves 2 clamps for the rear section (one on the top rail and one on the bottom) with a section of stock between them to keep the entire assembly from possibly rotating, and one clamp up front. I will post when it's built.
I pm'ed the seller of these mounting brackets on ebay. Their tech's said that the brackets (or at least ones that look identical) were designed to hang lead blocks used as ballast in race cars. That the hi-lift should not budge them one bit.
Layton
2007 FJ Cruiser 5AT 4x4
Voodoo Blue
"God forgives...rocks don't"
layonnn is offline
