Yesterday, those same four pesky engine lights that others have talked about ("Check Engine, Swerve, and both VSC") came on for the first time! I did a search on the Forum and removed and replaced the gas cap. No luck. I also disconnected the battery, and still the lights were on. I took it to my local dealer and they told me my Catalytic Converter was not as efficient as it should be and needs to be replaced. So, they ordered me a new one and I should have it installed within a week or so.
After less than three years and only 28K miles, is this normal? I don't know much about engines, but shouldn't something like this last longer? Any opinions?
Sun Fusion 4X4 AT CQ GY DL FE XY PW CA TC QS
Mods to date: New and Improved Tire cover, with the FJ, tire tracks, and the word "Cruiser" free-hand painted
A-Trac,Dual horn,Michelin Latitude Tours with MB Chaos wheels
Florida "Shark" specialty license plate saying "KRUSR"
No it's not normal and that is why they are replacing for free under warranty.
DEWFPO
Makes me wonder: We've all been force-fed ethanol gas for the past, what, four years? I wonder if everyone will begin to see the manifestations of catalyst damage due to the alcohol in fuel, due to long term exposure?
Where's my tin foil cap... Did you see that black helicopter? heh heh
Seriously, any chemical engineers in the house?
__________________ Dennis' Titanium 'Bird of Prey': '08 Titanium 4X4; AT; LD; A-Trac; Cobra CB radio & Bandi-mount mini whip; Yaesu FT-7800R HAM radio & Comet SBB7 hatch-mounted 5/8 wave antenna Call Sign: KE5WTX; Toyota extra horn mod; BajaRack Exp roof rack; 295/70/16 Hankook Dynapro MT tires; Factory off-road 16" alloys; OME 884 front coils & N140S shocks, ToyTec Medium rear coils, OME N71E rear shocks; SCUBA breather mod; Steel sway bar collars; Digger upper and lower rear links; Rasta4x4 skids; Metal Tech step sliders & front tube bumper; Hella 500's; Camping Labs RTT Future Mods: Cloaking Device, Disruptors
It's not like congress would ever mandate an ill-thought-out solution by law that actually made the problem worse, like MTBE.
N5MUD 4x4ham.com
TLCA # 16550
High Desert Cruisers
Some areas have used ethanol since 1985 (at first Denver only in winter), now year round. No problems with catalytic convertors. It might be other additives in the gas but I doubt it's the ethanol.
DEWFPO
Don't get me started on MtBE. What a debacle that was. I worked at Chevron back when it was mandated in CA and Chevron fought back hard to not use it. We proposed using ethanol instead (a proven additive). CA said, who cares what you want, you'll use MtBE and be happy about it. Well, it cost the oil companies and the state of CA billions of dollars to clean up and lawsuits not to mention all the money wasted changing over chemical plants to make this stuff. Back then you couldn't tell regulators anything. They seemed to have a allergic reaction to DATA.
DEWFPO
I just recently got those exact lights come on. However; when I accelerate, between 2000 and 2500 RPM's, I get a hesitation or jerk where the rpms jump from 2500 to 2000 then back to 2500. This happens in any gear. what do ya'll think?
Just for the record, here in California, not sure if it's the same for the rest of the US, the smog system on most cars has a longer factory warranty than the rest of the truck. My son's 03 second hand Toyota Matrix had 79,800 miles on it when the cat went out. Toyota replaced it under warranty. The cat was covered till 80,000. Have not read the fine print on the FJ but I'm guessing it is the same.
All-Pro skids, Stubbs Welding HD-SKO Rock Sliders, FT-8800R, Icon Stage 2, and 285/17/75 Nitto Terra Grapples.
