Old 06-24-2009, 10:27 AM   #1
Mr.FJT's Avatar
Member Number: 5191
Send a message via Yahoo to Mr.FJT
Question How long would the FJ idle for?
How long would the FJ idle for? Ya I know untell its out of gas. I want to know for camping and how much gas would be used if I left the FJ idleing for and hour.
Mr.FJT is offline
Old 06-24-2009, 11:08 AM   #2
BocaChaser's Avatar
Member Number: 17708
Re: How long would the FJ idle for?
a long time.....i have left it on for a couple hours with radio on and air conditioning and it really didnt seem to use up too much gas
BocaChaser is offline
Old 06-24-2009, 11:09 AM   #3
VoodooRocky's Avatar
Member Number: 9246
according to my scangage it burns .4 gallons per hr at idle......you do the math!! Voo
6 MT
K&N CAI,AFE TBS,UNICHIP,
JBA EXHAUST AND HEADERS
A TRACAH HACKAH
All Pro Skids MAGNASHIELDS
3 INCH ICON LIFT WTH BFG 265-70-17'S 1.50 SPACERS
MULTIVEX MIRRORS,BEST SAFETY MOD FOR FJ
COBRA CB,FIRESTICK,& BANDI MOUNT
SCANGAUGEII WEBASSOSUNROOF
AVIC D-3 NAV,XM,XM TRAFFIC,BLUETOOTH&BACK UP CAM
PIAA 500XT'S,PIAA1000XT'S,PIAA BULBS EVERYWHERE!!WOLO BADBOY HONKER
VoodooRocky is offline
Old 06-24-2009, 11:17 AM   #4
VT_RainMan's Avatar
Member Number: 10271
So know chance of overheating? That would be my only concern... probably not so much an issue on newer vehicles. I was always told it is bad to idle a vehicle for any long length of time.
2007 FJ 6MT black -n- black
VT_RainMan is offline
Old 06-24-2009, 11:32 AM   #5
Member Number: 14403
That's probably because of the cooling system unless the engine has a flawed oiling system.
The FJ uses a clutch fan and you're pretty much bulletproof unless the spring in the clutch goes to bed. Electric fans are as good as their electronics. Hot and cold do funny things with lots of things
JData is offline
Old 06-24-2009, 11:34 AM   #6
cnckart's Avatar
Member Number: 24296
I had mine idle for about 4 hours once when I was stuck in the snow and digging myself out. The gas gauge barely dropped, and the temp. stayed consistant.
08 Black Diamond Conv. Pkg. 6MT
Roof Rack
Hitch
Locker
$60 A-TRAC
ABS VSC OFF Switch. (fun button)
Passenger Arm Rest
Kenwood Deck Assorted Speakers
Rough Country 3" lift
BFG 285/70/17 All Terrains
Home Made light Bar
Cheap Auto Zone Lights
Custom Air Dam
Trail Gear Sliders
Full Ricochets
http://www.ricochetoffroad.com/
cnckart is offline
Old 06-24-2009, 02:29 PM   #7
Member Number: 24663
If you're that concerned about overheating (I wouldnt be) you could always open the hood.
Tre003 is offline
Old 06-24-2009, 03:46 PM   #8
MrBigAxe's Avatar
Member Number: 12016
Several members here have slept in theirs overnight with either the A/C or heat going.
2008 Sandstorm, AT, BajaRack, TG Sliders, 6 Circuit Accessory Fuse Box, Tacoma Fog Light Switches, SilverStar Ultras, Titan Air Jack, Cast Hi-lift, After-Market Power Inverter, Trail Team Badge, M-PAC Rear Door & Side Rack Combos, #10 CO2 Tank, aFe TBS CAI & Hi Tuck Exhaust, Icon Stage 1 Lift, Camburg UCA, Midland 75-822 w/Bandi & 3' Firefly, Wolo 120 Horns, 285/75/16 Maxxis Bighorns, Badger 5lb Fire Extinguisher.
MrBigAxe is offline
Old 06-25-2009, 05:53 PM   #9
DEWFPO's Avatar
Member Number: 7505
VT_RainMan previously said: View Post
The FJ has a very large (surface area), efficient radiator (as long as it's not coated with mud). Chances of it overheating are slim unless the fan clutch fails.
DEWFPO
Engine Block Heater, '08 Cyclone Pre-Filter, Dual horns, Phillips Osram 70W/65W H4's, RockBlocker and 3M Clear Film, Toyota RearSight Backup Camera.
"Enjoying the Journey"
DEWFPO is offline
Old 06-25-2009, 06:01 PM   #10
Dissident's Avatar
Member Number: 20326
Hmm, good thread. I've always wondered about that (plan on using mine to run tire warmers at the racetrack; it's cheaper and quieter than a generator)
__________________________________
The things you own end up owning you.
Dissident is offline
