Old 07-01-2009, 03:29 PM   #1
Skinpuppet's Avatar
Member Number: 442
Send a message via AIM to Skinpuppet
Wiring Winch
I just installed a Road Armor bumper with a Warn M8000 winch. Does anyone know the best way to run wires from the winch to the battery? I have never done this before. Any input would be great. Thank You.
Skinpuppet is offline
Old 07-01-2009, 05:28 PM   #2
Hondo's Avatar
Member Number: 13745
Re: Wiring Winch
On my ARB I followed the path of least resistance and avoided sharp bends on the sheet metal and used plenty of tie-wraps. I also check the cable for any chaffing after wheeling.
Hondo is offline
Old 07-01-2009, 07:02 PM   #3
Cogen Man's Avatar
Member Number: 3269
Re: Wiring Winch
I agree with Hondo. The path of least resistance. Best to route positive and negative wires over to the right and up through the right side round holes. I believe just below the right side light. Use as many zip ties as you need to secure the lines. Some rubber tubing is advisable where the lines go through the holes. Also remember when you make your connections, the negative connection must be made to the negative battery terminal and not to ground on the body. Of course positive connection to the positive battery terminal.
Silly Wabbit
Mods:
BFG AT's, stone guard,vent visors,window tint,blacked out bezel/rear bumper.
Joels grab handles. See Avatar.
Demello front winch bumper/center hoop/Acro lights
Titan 12k winch,recovery gear
Scangauge II
Joel's FJC badge
Gobi Ladder
Custom rock rails
Quick Fist Clamps
Tuffy security console
Future Mods:
Demello rear bumper
http://www.fjcruisersontario.com/wordpress/
Cogen Man is offline
Old 07-01-2009, 07:50 PM   #4
AA2D's Avatar
Member Number: 21785
Re: Wiring Winch
As Cogen Man has said, tie wrap split rubber tubing around each conductor as you pass through the holes to the right of the radiator into the engine compartment. You definitely don't want them to rub through the insulation there as it would be a dead short!
2008 Sandstorm 6MT
285/75/16 Cooper STT, DO Front Bumper, Warn M-8000, TG Sliders, Sway-Away Racerunner on all 4 corners, Camburg UCAs, Scan Guage, Hella 4000, Acro lights in Bumper, Cobra 75WX CB Radio.
AA2D is offline
Old 07-06-2009, 04:20 PM   #5
Skinpuppet's Avatar
Member Number: 442
Re: Wiring Winch
Do you mount the motor ground cable for the winch to the winch or anywhere that is metal?
Old 07-06-2009, 04:57 PM   #6
Cogen Man's Avatar
Member Number: 3269
Re: Wiring Winch
Skinpuppet previously said: View Post
This might help ya.
http://www.warn.com/truck/winches/sr...1/36138-D3.pdf
The motor ground cable goes from the control box to a ground bolt under the winch motor. Be sure to use a little di-electric grease on all your connections.
Silly Wabbit
Mods:
Scangauge II
Joel's FJC badge
Gobi Ladder
Custom rock rails
Quick Fist Clamps
Future Mods:
Demello rear bumper
