Old 09-01-2009, 09:46 PM   #1 (permalink)
PENROSE's Avatar
Member Number: 16223
bad wheel bearing covered under warranty??
Im hearing a "whine/howl" coming from the rear at 60mph....its annoying even with radio up loud. Not sure if its the bearing but...
Anyway...I have 29,000 miles
2007 Black Cherry 4x4, Upgrade and Convenience Pkgs, RC 6" Lift, 17x9 Gear Alloys, 315x70x17, Body Mounts "chopped", Magnaflow Exhaust, Spidertrax 1.25", OEM Brushgaurd, SRS lower bumper guard, Geartype Razor Wings, PIAA 520i fogs, Blacked-out bumpers/mirrors/handles
PENROSE is online now
Old 09-01-2009, 11:10 PM   #2 (permalink)
DoWork's Avatar
Member Number: 18372
Re: bad wheel bearing covered under warranty??
Your under warranty. Take it in
-Mark
08' Black Diamond FJ
View my build
http://www.fjcruiserforums.com/forum...ml#post1145216
DoWork is offline
Old 09-01-2009, 11:37 PM   #3 (permalink)
cnckart's Avatar
Member Number: 24296
If it is a wheel bearing yeah should be covered. Not much you can do to take out a wheel bearing unless they find all the grease flushed out and it's packed full of mud Anything short of that and you should be ok.
MY BUILD THREAD
THE SPACE CRUISER
http://www.fjcruiserforums.com/forum...ser-build.html
Thanks to the following people and companies that have contributed to my build.
Arien @ Demello Offroad
Doc @ Springtail Solutions
Digger @ Outrider
TLCA# 20167
http://www.ricochetoffroad.com/
cnckart is offline
Old 09-02-2009, 07:15 PM   #4 (permalink)
PENROSE's Avatar
Well, I'm pretty sure its not packed with mud, as I rarely go offroad....this is my daily driver haha.
However, I DO have a 6 inch lift, aftermarket wheels, 35 inch tires, AND wheel spacers. I'm thinking this combo might void my warranty?? If I do take it in.....I will take the wheel spacers off beforehand.
I have mud tires (Firestones)....and this noise started shortly after I had them rotated (this is the first rotation for them). I'm thinking I could have a cupped tire? Guy at tire shop said tires could be "stepping" (thats when you run your hand over your tire and it feels smooth in one direction...but feels "choppy" when you rub it the other direction. I did this, and they are indeed stepping. He said to drive on them for 1,000 miles and it should go away after the tires wear a bit more.
I had both my front and rear differentials along with my driveshaft checked.....they all look fine.
I think it might be the tires........(or a wheel bearing, haha)
Old 09-02-2009, 07:28 PM   #5 (permalink)
cnckart's Avatar
Even with wheel spacers etc. I think you would take out a ball joint before a wheel bearing. Thats what my old 4runner did . Sounds like it may be tires, drive on them for a bit and let them "wear in", or rotate them to see if there is any difference in noise.
MY BUILD THREAD
THE SPACE CRUISER
Digger @ Outrider
TLCA# 20167
cnckart is offline
