Old 10-28-2009, 06:00 PM   #1 (permalink)
Roadrash's Avatar
Member Number: 30846
Scuba Mod Question
I have read most of the scuba mod threads and even seen a scuba mod on You Tube, my question is has anybody done the Scuba Mod with all the components tied into one vent line? Would that be to much for one vent line.
RR
07 FJ Sun Fusion,AT 4X4,A-Trac,Rear Locking Diff,17" Steel,BFG AT KO's 285/70/17,
All Pro Sliders,Gobbi Ladder,K&N Filter,ToyTec Diff Drop, ToyTec Sway Bar Relo,TRD exhaust,3" Pro Comp Lift, Ricochet Skids,LED Domes, Blacked Out,Scuba Mod, LR UCA's, Snorkel, Garvin Basket, ToyTec LCA,s
Roadrash is offline
Old 10-28-2009, 06:11 PM   #2 (permalink)
fj6high's Avatar
Member Number: 17218
Re: Scuba Mod Question
I believe some members have plumbed it all to one. I have all my things plumbed to two filters. I believe as long as air can move freely thru the hose lines to releive pressure or contraction then your good to go.
Fabtech 6" Lift + OME 3" 20" BBS rims Nitto 35"s AT,1.25 spacers,Bushwhackers, VR3 The Toy Outfitters bumper ,55 watt fogs,TG sliders, Manik tailight guards, Stallion Light bar,55 watt Baja lights, Cobra 19 SXIV PA, Bandi 4' fire stick, K & N filter, Locker on demand, ATrac hack, VSC & DRL switches, TRD Cat back, Scuba Mod, Garmin Nuvi 200 BlueSeas 6 fuse Interior: leather seats, dual arm rests, dual factory DVD players, Diamond interior trim, Source 10lb, Rubber mats. TT and FJC Badge.
fj6high is offline
Old 10-28-2009, 06:32 PM   #3 (permalink)
FJNewb's Avatar
Member Number: 19411
My design has it all going into one filter. Look at the 3rd page in my build thread...think there are some pictures there.
FJNewb is offline
Old 10-28-2009, 06:46 PM   #4 (permalink)
Scuba's Avatar
Member Number: 31106
There's a mod named after me now..?
I wheel Taco on da rocks
Scuba is offline
Old 10-28-2009, 08:19 PM   #5 (permalink)
rrjames's Avatar
Member Number: 15828
You should have no problems running it through one line. I have sided in favor of multiple short lines so once I am done I will have breathers in the center console for the transmission and transfer.
Scuba previously said: View Post
I'm actually shocked that that screen name was available till 2009.
08 Trail Teams 6MT
The Polar Bear
rrjames is offline
Old 10-28-2009, 08:41 PM   #6 (permalink)
carlgcs's Avatar
Member Number: 13261
Uh, the mod was here long before you!
You are named after the mod!
Build Page
TLCA #19572
GCLC #2129
FJNortheasters
carlgcs is offline
Old 10-28-2009, 08:47 PM   #7 (permalink)
Roadrash's Avatar
If you bring the vent lines into the center console are you worried about the smell, I must assume their will be some sort of odors from the oils inside the components.
RR
Roadrash is offline
Old 10-28-2009, 09:42 PM   #8 (permalink)
FJ-Fred's Avatar
Member Number: 18081
I have them all tied into one filtered line that pops up where the jack compartment is. No problems, no odors.
CENSORED
Forum administrators prohibit my listing anything of value here.
FJ-Fred is offline
Old 10-28-2009, 10:21 PM   #9 (permalink)
Ric
Ric's Avatar
Member Number: 8130
Are you talking about the Rear Diff. Breather mod ? Rear diff breather install - Toyota 120 Platforms Forum
Ric is offline
Old 10-29-2009, 02:12 PM   #10 (permalink)
VT_RainMan's Avatar
Member Number: 10271
Ric previously said: View Post
Rear diff, transfer case and front diff tied to one.
SCUBA Driver Transmission, Transfer Case, Rear Differential & E-Locker Breather MOD
2007 FJ 6MT black -n- black
VT_RainMan is offline
