Whats the best way to connect you amp power cable to baterry is woofer is under seat? - Toyota FJ Cruiser Forum
post #1 of 15 (permalink) Old 12-01-2011, 07:56 PM Thread Starter
Quoted: 0 Post(s)
I'm trying to instal the power wiring to my sub under driver seat what is the best way to installed?
jrsierra24 is offline
post #2 of 15 (permalink) Old 12-01-2011, 08:37 PM
Zombinator's Avatar
Quoted: 0 Post(s)
Re: Whats the best way to connect you amp power cable to baterry is woofer is under s
The best place is down the driver-side. There is a plug in the firewall on the driver-side aft of the battery that works well then run it down and along the door threshold.
You might need to ream the hole in the firewall a little if you use a large gauge wire.
See pictures of my install:
ID:	50453   Click image for larger version
ID:	50454   Click image for larger version
ID:	50455   Click image for larger version
ID:	50456   Click image for larger version
Zombinator is offline
post #3 of 15 (permalink) Old 12-01-2011, 08:40 PM Thread Starter
Quoted: 0 Post(s)
thanks!!! this means that if the wire in not that big i don'y need to drill?
post #4 of 15 (permalink) Old 12-01-2011, 08:44 PM
Zombinator's Avatar
Quoted: 0 Post(s)
Here are some more images:
Assuming you route the RCAs under the center console, routing the power along the door frame works best because you want to keep the low level signal (RCAs) away from the high power sources (Power wires and speaker wires), in order to minimize introducing noise.
ID:	50459   Click image for larger version
ID:	50460   Click image for larger version
ID:	50461   Click image for larger version
post #5 of 15 (permalink) Old 12-01-2011, 08:47 PM
Zombinator's Avatar
Quoted: 0 Post(s)
jrsierra24 previously said: View Post
Correct. A four gauge wire or smaller should fit fine. What you see in my pictures is a 0 gauge wire. I am running a 1200 watt amp under the driver-side and a 600 watt amp under the passenger-side thus the big wire.
post #6 of 15 (permalink) Old 12-01-2011, 08:49 PM Thread Starter
Quoted: 0 Post(s)
wow thanks!! does installing rear speakers a big upgrade...I'm installing 2, 6.5 seakers on door a dvd kenwood and a sound ordenance sub? any ideas?
post #7 of 15 (permalink) Old 12-01-2011, 09:10 PM
Zombinator's Avatar
Quoted: 0 Post(s)
What most people, including myself do is install them in the panels in the rear seat area and just disconnect the factory speakers in the rear pillars. Wicked CAS sells a pod adapter for this if you don't want to fabricate your own.
If you are installing 6x9s, you may not need it but, they also had a front pillar pod
I might also point out that if you buy the speakers and the pod from them, they give you a really good package deal which goes a long way toward offsetting the added cost of the pods.
post #8 of 15 (permalink) Old 12-02-2011, 06:38 AM Thread Starter
Quoted: 0 Post(s)
great!!!! so were do I get the wiring to install those speakers. Do I need to install new wiring?
post #9 of 15 (permalink) Old 12-02-2011, 06:39 AM Thread Starter
Quoted: 0 Post(s)
do i nned to cut frame or something?
post #10 of 15 (permalink) Old 12-02-2011, 07:36 AM
Zombinator's Avatar
Quoted: 0 Post(s)
If you are installing an amp under the seat, then yes, you will need to install new wires to the speakers. The best way is to run it through the door grommet. Its really easy. Here is a thread that shows pictures of a door speaker installation.
Wiring Front Door & TacoTunes Altnerative - PICS
You should not need to cut anything (other than maybe a hole in the carpet)
  Toyota FJ Cruiser Forum > Newbie Town > Newbie Discussions
Human Verification
