Re: Brand new TT revs on its own?
Ok the computer learning makes perfect sense. I had the battery disconnected for a long time while installing the HID headlights yesterday. I drove the FJ about a hundred miles today and now it is doing what Landdozer said:
"Mine Idles around 900-750 rpm when normal. While driving, if I coast in neutral or in between gear changes it will be around 1200 rpm. I don't know why."
When I push the clutch in it revs up about 300, then drops down to about 1500 and holds there. I'm assuming its doing the 1500 thing because its cold.
So my next question is, does anyone make an aftermarket tuner that will keep it from revving up 300 rpm when I push in the clutch? That is annoying and the exact opposite of what I need it to do when i'm up shifting under normal acceleration. Its forcing the transmission to synchronize the speed if I shift quickly (hard on the clutch), or makes me wait a long time for the revs to drop between shifts.
Reason: I learnt english gooder than you.
