High Voltage problems.... - Toyota FJ Cruiser Forum
post #1 of 9 (permalink) Old 03-01-2013, 11:18 AM Thread Starter
Quoted: 0 Post(s)
I just bought a 2007 Fj Cruiser and I was out driving the other night and my stereo shut of then turned back on and all my dash lights came on (ABS TRACTION CONTROL VSC) and i stoped and shut it off and turned it back on and they went off so i kept driving but the next day goin to work it did it again but this time i noticed the in dash volt meter was way higher than normal and it would go up the higher the rpms got. So what do you guys think it is? Voltage regulator maybe? Or bad battery? Or bad alternator? And is the voltage regulator built into the alternator?
boshgr is offline
post #2 of 9 (permalink) Old 03-01-2013, 11:29 AM
Lmmmmm's Avatar
Quoted: 132 Post(s)
Re: High Voltage problems....
welcome.
you need to test the battery voltage and see what it is putting out.
2011 NSSE - Icon coilover - TotalChaos UCA - SAW rear coils - OME 895 rear medium shocks - Metal Tech slider - Metal Tech tube bumper - Viper Elite 10k Winch - PIAA 520 ATP - Midland 75-822 CB - Boztec antenna mount - Duratrac 285/70x17 - Scuba Mod - Ricochet skids - PIAA dual horn 400/500 - sPOD - Ellis Stealth Shift Knobs - MPAC rear/side rack - PLX Kiwi Bluetooth OBDII - Nestah Edition Firestik Radio Antenna - National Luna Single Battery Monitor - Tantrum Rock Lights - Outrider Shock Armor - Toy Outfitter LCA - Switched DRL's - Front rock cameras - Custom Rear Cargo Storage - Platinum PM-1 Battery - Raingler Cargo Nets - 10LB Powertank
Lmmmmm is offline
post #3 of 9 (permalink) Old 03-01-2013, 11:54 AM Thread Starter
Quoted: 0 Post(s)
Lmmmmm previously said: View Post
welcome.
Well it only does it for a couple min then goes back to normal... ive tried testing it while it was high but i never can get pulled over before it starts working fine again
boshgr is offline
post #4 of 9 (permalink) Old 03-01-2013, 11:57 AM
Vegas_Nick's Avatar
Quoted: 403 Post(s)
Bad battery more than likely. That high voltage is indicative of that.
Pull it out and get it load tested.
Vegas_Nick is offline
post #5 of 9 (permalink) Old 03-01-2013, 03:32 PM Thread Starter
Quoted: 0 Post(s)
Vegas_Nick previously said: View Post
I took it out and had it tested on a battery tester and it read good but i put it on the load tester and it was good until we put the actual load on to it then it went bad but we retried it and it read good but it was smelling kinda funny and sounded like something was sparking and it kinda looked like the battery was disformed so i got a new one... hope this works
boshgr is offline
post #6 of 9 (permalink) Old 03-01-2013, 05:32 PM
Attilla's Avatar
Quoted: 1 Post(s)
Six years old, maybe seven if its the factory battery, way overdue....
In AZ I trade mine out at 3 years just to be safe, the heat really kills them....
Hope it worked, check back in on it....
08' FJ 4x4
TRD SuperCharger
AFE 3" mandrel with 4" Chrome tip
TRD CAI, URD offroad pipe
Factory Rock Rails
3 1/2" Rough Country front
2" Daystar Spacer Lift rear
Body Mount Chop
285x70x17 Big O Bigfoots
Fumoto Valve
40" Light Bar
Rigid Industries Lighting
TUFF Console
2014 wheels - 7 spoke silver
(2) Pioneer Subs 10's in SubThumps
Pioneer AVIC-X940BT with backing camera
Rockford Fosgate P321 (f & r)
Scan Gauge II
9mm with 10 hollow points in pocket, 33 mag in other
Attilla is offline
post #7 of 9 (permalink) Old 03-05-2013, 06:02 PM Thread Starter
Quoted: 0 Post(s)
So the new battery seems to have fixed the problem so far.... but new question..... Is there anyone who lives near me (Green River Wy) that has done those hacks for A-Trac and traction control and rear lockers and all that stuff that could help me cuz im freaking lost with all the threads ive read!
boshgr is offline
post #8 of 9 (permalink) Old 03-06-2013, 01:16 PM
Datajockeys's Avatar
Quoted: 158 Post(s)
You may want start a new thread in the Regional forum or the Electrical forum to get a better response.
Army Green 2011 NSSE (Option Package 3) w/ Tribal Graphics
Datajockeys is offline
post #9 of 9 (permalink) Old 12-08-2013, 12:39 PM
suprteck's Avatar
Quoted: 0 Post(s)
boshgr previously said: View Post
I had the same problem the other night. My battery gauge was reading higher than normal and fluctuating. Also notice my dash lights and headlights flickering. Then once all my warning lights came on for a second. So I hooked up my DMM and watched it while i had the car running. The voltage was reading 13.7 volts but would go up to 15 volts at times. At first I thought it was a bad alternator putting on too much voltage. But turns out my 1 year Sears PM1 was bad.
suprteck is offline
  Toyota FJ Cruiser Forum > Newbie Town > Newbie Discussions
Human Verification
