Front end creaking noise - Toyota FJ Cruiser Forum
post #1 of 7 (permalink) Old 04-30-2013, 08:35 PM Thread Starter
Quoted: 0 Post(s)
Question Front end creaking noise
I've begun to notice a creaking noise coming from the front end of my FJ when the road bends, but not so much when I make turns at intersections or maneuver in the parking lot. It's only audible with the windows rolled down and sounds like a slowly shutting creaky door. It's not as noticeable while driving straight. At first I thought it was my aftermarket front bumper or the suspension, but it doesn't accentuate when rolling over bumps in the road.
It's a 2008 with 70,000 miles and an OME Heavy lift with 285s on stock 17s. I hope it's something as simple as getting a lube job and not something more serious like needing new control arms.
Has anyone else had a similar issue?
Thank you in advance!
The Sports Dude is offline
post #2 of 7 (permalink) Old 04-30-2013, 09:56 PM
Smalldog's Avatar
Quoted: 645 Post(s)
Re: Front end creaking noise
I had a similar creak or groan and it was my UCA bushing groaning because it was embedded with dirt. I doused the top of the uniball with Tri Flow and it solved it...for now anyway
Sent from AutoGuide.com App
  • 2007 Voodoo 6MT
  • AllPro Walker Evans lift
  • AllPro Uniball UCAs
  • Allpro Rear Lower Links
  • Allpro Roof Rack
  • LCNW Front Tube Bumper
  • LCNW Rear Tube Bumper
  • Warn 9.5 TI Winch with Syn Line
  • Stealth Custom Series Matte Bronze Wheels
  • 285 70 17 Duratracs
  • URD 6MT Quickshifter
Smalldog is offline
post #3 of 7 (permalink) Old 05-01-2013, 11:33 PM Thread Starter
Quoted: 0 Post(s)
Smalldog previously said: View Post
Thanks! There are no adverse effects of Tri Flow on the rubber bushing?
post #4 of 7 (permalink) Old 05-01-2013, 11:45 PM
Smalldog's Avatar
Quoted: 645 Post(s)
The Sports Dude previously said: View Post
Good question. I don't know. I have read that the UCA uniballs shouldn't be lubed at all for that reason, but it seemed I had no choice other than to press a new bushing in there to stop the groan.
It was worth the risk for me because the triflow immediately silenced the groan. I'm just biding time to press new bushings anyway but if the triflow keeps doing the job, I might be good for a long time
  • 2007 Voodoo 6MT
  • Allpro Roof Rack
Smalldog is offline
post #5 of 7 (permalink) Old 05-02-2013, 12:30 AM
foxhead's Avatar
Location: East bay, Ca and Bozeman, Montana For College
Quoted: 1 Post(s)
I've never used triflow on a car before, but i've used it on countless bike parts and its a tried and true product in my book! You should be fine
"Life makes everyone suffer, its those that can suffer the most that will come out on top" - Tyla Rattray
Project Trail Whale:http://www.fjcruiserforums.com/forum...ail-whale.html
"It doesn't matter how capable your rig is if you don't wheel it"
foxhead is offline
post #6 of 7 (permalink) Old 05-02-2013, 12:48 AM
Quoted: 671 Post(s)
Stock control arms or aftermarket??? If stock this sounds like very dry seized control arm bushings you should be able to replicate by pushing down on the bumper. Triflow is ok on the rubber but the arms should be taken apart cleaned and lubed.
After market arms if they are hiem joint style any thing like Triflow will attract more dirt . I would clean the joint and use silicone or dry grafite lube.
WaJohnZ is offline
post #7 of 7 (permalink) Old 05-02-2013, 07:09 AM
Evil Trunk Monkey's Avatar
Quoted: 15 Post(s)
Two squeaks that sound similar other than UCA:
1) the plastic front bezel took a hit on one of my FJs and squeaked thereafter (reproducible by pushing on a corner of it)
2) aftermarket bumper? Some make contact with the bolt that sticks off the AC radiator pipe (not sure if that is actual name but one skinny pipe in front of your radiator has a bolt near bottom sticking out toward front). A piece of rubber in between will keep the metal contact from squeaking.
Build Thread! Firefly 2012 TT
Evil Trunk Monkey is offline
  Toyota FJ Cruiser Forum > Newbie Town > Newbie Discussions
Human Verification
