I've had my M/T FJ a week now, and after a couple hundred easy miles it seems that after letting off of the gas coming up to a stop it seems to want to stay in gear. The only way to describe it is there seems to be a drag slowing it down. I've had many other trucks before, including toyotas, and never really has a vehicle roll after letting up on the gas with such a drag before. It is common for all FJ's to do this, or does any one know why it does if it is normal???
Re: A/T seems to drag after letting up off the gas
mine does this as well, the computor is tell the tranny to help slow the vehicle. this does not happen after 3rd gear. i have noticed. no problem, just normal fj keeping us safe. on and off.
It kinds drives me nuts cause i still look down to see if im stepping on the brake or something, quite annoying. I didnt realize it did this when I test drove it, i was too occupied admiring all the things I liked about it instead of looking at the things I didnt. Has anybody ever heard from toyota what their reasoning for this is? I have to beleive it cant be good for the drive train, and probably would cause premature wear on parts.
anhh, when i do notice it, i just say thanks to toyota for building that in, to keep me straight. Of course I live in the smokey mountains. lost and lots of steep hills
It's the "grade logic" programmed into the shifting parameters. It helps with descents by holding a lower gear. It's activated by an application of the brakes usually.
This is what edmunds had to say about it in regards to it's behavior in the 2007 Tundra: Particularly impressive is the downhill grade logic. On a long descent, we didn't need to touch the brakes, as the transmission downshifts and steadfastly holds the lower gear.
It feels similar to my Rubicon that had 4.10 gears when you let up on the gas, it slows down considerably--great for saving on brakes and shorter stopping distances.
