CDRacingZX6R previously said:
Just wondering how close I am to a particular meeting place if I can only get this many digits onto my Eclipse navigation. EXample:
It should be this..
LAT 33 38 14.9N
LON 117 25 17.2W
It only lets me put in this
LAT 33 38 14N
LON 117 25 17W
How far off from the original location will I be? Feet, miles? I know nothing at all about how this crap works, but I'm attempting to find an easiyer way to start local trails than word of mouth instructions.
Thanks!!
The coordinates you are giving are formatted in Degrees Minutes Seconds, so you need to know how much distance on the ground one second (or fraction thereof) represents. In Latitude, this is a constant, about 6,800 feet (rounded off). In Longitude, the distance on the ground varies with how far north or south you are - because the earth is curved, a second of longitude is a longer distance at the equator than it is near the north pole.
The quick but not perfectly accurate answer to your question is, using 6,800 feet per second of latitude, that is your greatest margin of error if you can only read seconds and not tenths of seconds on your GPS. You could be 1.3 miles off. If your GPS will read in tenths of a second, you cut your maximum error down to about 680 feet.
All of the GPS's I've ever had would display D:M:S at least in tenths of a second, but I prefer to work in decimal degrees and most of them will display five or six decimal places that way. Somewhere in your setup menus, you should be able to change the lat/long format.
