» Auto Resources
» Sponsor Links
»Garage Storage and Cabinets
Old 10-10-2007, 11:25 AM   #1 (permalink)
Member Number: 14386
Water Leaks And Fording Water
I was out on the weekend and got in a rather deep hole. I ended up with water in my rear hatch and under the floor??? has any one experienced this yet?
phinman is offline
Old 10-10-2007, 11:28 AM   #2 (permalink)
sealevel's Avatar
Member Number: 4281
Send a message via AIM to sealevel
Re: Water Leaks And Fording Water
I have had mine in water up to the headlights in a creek bed for about 15-20 minutes and no leaks. Moving most of the time. No problems here.
sealevel is offline
Old 10-10-2007, 11:30 AM   #3 (permalink)
Thumbs down Re: Water Leaks And Fording Water
I was in a mud hole and got stuck stirred up the mud good and am now cleaning out the back door and have pulled the plugs on the bottom of the fj and the insulation is soaked?? and did any water come in the inside of the fj??
phinman is offline
Old 10-10-2007, 11:42 AM   #4 (permalink)
SonicFJ's Avatar
Member Number: 6368
The rear door has drain holes in the bottom. They will allow water in as well as out. Sitting still in water over the door sills (front or back) is a recipie for disaster. It will get under the rubber mat and cause all sorts of odor and electric problems if not eventually removed. If you suspect water under the mats, remove the sills and inspect under the mat. If the rear door retains water, clean out the holes at the bottom of the door and it will finish draining.
SonicFJ
SonicFJ is offline
Old 10-10-2007, 11:42 AM   #5 (permalink)
Ospreyguy's Avatar
Member Number: 3301
phinman previously said: View Post
I don't know, did it? I am not sure I follow you. Are you asking sealevel if his insulation is soaked or what?
mike5 out
A/T - Black Diamond
Fair Tax Now!
Insults you are not good at zero!!
Ospreyguy is offline
Old 10-10-2007, 11:44 AM   #6 (permalink)
sealevel's Avatar
Member Number: 4281
I inspected the doors and floors as well as underneath after getting home and found it all dry, fyi.
sealevel is offline
Old 10-10-2007, 11:47 AM   #7 (permalink)
Yes I was just asking sealevel about his.
BUt I assume I am going to have to take the seats out and the flooring out to get to the insulation. Take it out then let it dry.
phinman is offline
Old 10-10-2007, 02:37 PM   #8 (permalink)
DEWFPO's Avatar
Member Number: 7505
I would also check the fluid in the rear diff for water. The rear diff and e-locker (if equipped) vents are located below the rear sill.
DEWFPO
"Enjoying the Journey"
DEWFPO is offline
Old 10-10-2007, 02:44 PM   #9 (permalink)
CRAW's Avatar
Member Number: 5153
Send a message via Yahoo to CRAW
EDIT: Never mind.
CRAW is offline
