Old 02-02-2008, 05:49 PM   #1 (permalink)
ivegonegolfin's Avatar
Member Number: 17208
Programing Remote Keys
I want to know if anyone knows how to program the remotes to open both/all the doors at the same time with just pushing the bottom once??? The manual says to contact the dealer and they will be able to... With my dodge ram I could do myself but that was four years ago and I've forgotten how..... Was pushing bottoms in a certain sequence??? any ideas
ivegonegolfin is offline
Old 02-02-2008, 06:08 PM   #2 (permalink)
Gone2Baja's Avatar
Member Number: 6979
Re: Programing Remote Keys
ivegonegolfin previously said: View Post
Does anyone know how to program the remotes to open both doors at the same time with just pushing the bottom once???
I just bought 2 from a board member {great guy and great price} I took them to the dealer and 45min and $48.00 later I was out the door with 2 extra remotes. Always nice to have extras.
I'd also like to know if that is possible.
Last edited by Gone2Baja : 02-02-2008 at 06:15 PM. Reason: I'm a dumb a$$ and didn't read the post carefully
Gone2Baja is offline
Old 02-02-2008, 09:04 PM   #3 (permalink)
The Laughing Moderator
LandCruiserSteve's Avatar
Member Number: 8627
Yep. Next time you're at the dealer, tell them you want the "one push" remote button re-programming. Takes about 5 minutes and most (decent) dealerships will do it for free.
Steve
The '07 Kiroi Hako
'59 FJ25
'78 FJ40
TLCA #6727
UFWDA
LandCruiserSteve is offline
Old 02-02-2008, 10:07 PM   #4 (permalink)
bluepete's Avatar
Member Number: 10610
Here's what I got from my dealer. I never got it to work right, but you're welcome to give it a shot or ask your dealer and they should do it for free...
hese are the directions you are looking for to manually reprogram for one click unlock of all doors. Let me know how this works!
(You'll need to complete all of these steps within 40 seconds or it will not program)
-Open the Drivers Door
-Remove Key From Ignition
-Insert Key Into Ignition Twice (In, Out, In, Out)
-Close the Driver's Door Twice--Remember, it should be open! (Close, Open, Close, Open)
-Insert Key In and Out of Ignition Once (In, Out)
-Close the Driver's Door Twice--It should be open! (Close, Open, Close, Open)
-Insert Key Into Ignition but do not remove it!
-Turn the Key from Lock to On 4 Times (Lock, On, Lock, On, Lock, On, Lock, On)
-After the locks stop, remove the key from the ignition switch
On your key fob you will need to press and relase both the 'Lock' and 'Unlock' buttons simultaneously.
Then simply press and release the 'Unlock' button and open the driver's door. That's it. All doors should unlock now the first time you press unlock. If not, try it again, it may take a couple of times to get it programmed.
Note: If you would like to return to driver's door unlock then unlock all doors you need to follow the same procedure except press the 'Lock' button instead of the 'Unlock' button in the last step.
bluepete is offline
Old 02-02-2008, 10:12 PM   #5 (permalink)
dbbd1's Avatar
Member Number: 1611
Thanks (if it works)
dbbd1 is offline
Old 02-03-2008, 04:02 AM   #6 (permalink)
chichid65's Avatar
Member Number: 15447
Thanks Steve. I'm taking mine in for the 5k in the morning and will ask to have this done. I'll let you guys know if I'm going to a decent dealership or not (if they charge me) I may have to stick with the "2 push" mode.
"A Year Of Change"
2008 FJ-VooDoo blue/4x4/AT/GPS/K&N Air Filter/Revos/Up Pkg.2/VIP RS3200 Plus Security System/OEM Roof Rack/OEM Rock Rails/Tow Package/All Weather Floor Mats & Rear cargo Mat//Recovery strap.
chichid65 is offline
Old 02-04-2008, 02:22 PM   #7 (permalink)
bluepete previously said: View Post
This must be a joke...... I felt stupid and my wife said I looked stupid and that someone was pulling my leg....By the way it didn't work....... if not thanks for your help but not much help
Old 02-04-2008, 03:38 PM   #8 (permalink)
iCruiser's Avatar
Member Number: 479
Too bad it didn't work, but I just did one for our Toyota Sienna, and it had similar instructions (open door, put key in/out open/close door) and it worked fine. Sometimes it's all in the timing!
I'll compare the two instruction sets when I get home and see if they are the same.
T
TLC #17889
In service: March 25th, 2006
ARB Front Bumper, GOBI Stealth, Dirty Part's 2nd Battery Kit, Original Bandi Mount #11, OME 883, ARB Fridge, FJoel Battery Clamp
iCruiser is offline
Old 02-04-2008, 10:34 PM   #9 (permalink)
Decidion's Avatar
Member Number: 13809
The reason this didn't work was that you forgot the step to hop on one foot while spinning in a circle 3 times...all while removing and reinstalling the roof rack twice.
Decidion (Jeff)
'08 Brick Red
CF-CQ-UR-3T-C7-2Q | OEM Brush Guard || OEM Rock Rails | Tail light Guards | Magnaflow 11226 | AFE CAI | Bud Built Skids | Custom Console | VentShades | SCUBA Driver Mod | Blacked-out Bumpers | Rear Storage Shelf | IPF 968s w/Clear Covers | BFG 285/70R17 A/T KOs | SAW RaceRunners | Hi-Lift Extreme | Staun Deflators | Midland 75-822 w/Bandi Mount | OXT Shock Guards | Tantrum Rock Lights | Kelty CarTarp
Decidion is offline
Old 02-05-2008, 07:20 AM   #10 (permalink)
Member Number: 14403
Decidion previously said: View Post
ROFL!
JData is offline
