Here's two newby questions. I have an FJ with the off road pkg. It has the 265-75,16" tires. Do I have more ground clearance than the others with the 265-70, 17" tires?
Also, will duplicate keys start the FJ with the theft deterant system?
no.
a 16'' tire is actually a fraction of an inch smaller.
and the duplicate keys toyota gave you should have the chips in them, unless you made one at home depot yourself.
i was once a rich man. spent my fortune on whores and drink.
Thanks. I thought the ground clearance would be about the same. So if i understand, a key cut from the origional toyota keys won't start the FJ?
thanks again.
A point of clarification for others reading this..... Only the '08's have chips in the keys, the '07's don't. The OP has the Off-Road package so it's an '08 and therefore has the key chip.
DEWFPO
I wonder if the 08 chip only applies to the ignition. I'm thinking, a home depot key would be OK to keep in your wallet in case you accidentally lock yourself out of the truck with the OEM key inside. I did this with a flat no chip key from a locksmith, so it wouldn't bulge my wallet too much. Of course, I have an 07.
I think your right. A non chip key should get you into the vehicle.
DEWFPO
