» Site Navigation
» Other Vehicles
03-22-2008, 05:12 PM
#1 (permalink )
Member Number: 18410
VVT-i ???
My lack of knowledge has no bounds.
What does the VVT-i stand for on the shroud of the motor stand for?
The story of deeds will live while mere words, full of sound and fury signifying nothing will perish untimely.
03-22-2008, 05:17 PM
#2 (permalink )
Member Number: 471
Re: VVT-i ???
Variable Valve Timing with intelligence (VVT-i) This system selects the ideal intake and exhaust valve overlap under all engine operating conditions. VVT-i virtually eliminates the traditional compromises between low-end torque and high-rpm horsepower. It also helps enhance fuel economy and reduces emissions so effectively that it eliminates the need for the exhaust gas recirculation (EGR) emissions device.
http://www.toyota.com/help/glossary.html#v
Women and cats will do as they please,
men and dogs should relax and get used to the idea
Robert A. Heinlein
#3 (permalink )
Member Number: 10006
Re: VVT-i ???
Variable valve timing is the first part. I don't really know what it does though.
03-22-2008, 05:18 PM
#4 (permalink )
Member Number: 10923
Re: VVT-i ???
Variable Valve Timing Intelligent
03-22-2008, 05:30 PM
#5 (permalink )
Member Number: 11965
Re: VVT-i ???
I've been looking for the RPM crossover point but haven't had any luck finding it, does anyone know what it is?
Current stable:
96 Integra LS
07 MDX Sport/Tech/Ent
07 FJ BC/MT/CQ/ATRAC/BFG KM2s -more to come
Fold, it does the body good:
teamWTFonline
03-22-2008, 05:36 PM
#6 (permalink )
Member Number: 471
Re: VVT-i ???
It's not a fixed point. It depends on engine temp, throttle position and engine load.
Robert A. Heinlein
03-22-2008, 05:39 PM
#7 (permalink )
Re: VVT-i ???
Wow that sounds fancy. Thanks
03-22-2008, 06:45 PM
#8 (permalink )
Re: VVT-i ???
Hmm...on the celica 2zz it was a fixed point, so what's the range?
Current stable:
96 Integra LS
teamWTFonline
03-22-2008, 06:51 PM
#9 (permalink )
Member Number: 442
Re: VVT-i ???
Thanx learn something new everyday
03-22-2008, 07:27 PM
#10 (permalink )
Member Number: 7505
Re: VVT-i ???
On the 1GR-FE only the intake valves are variable. Up to 50 degrees early and up to 50 degrees late so a variable range of 100 degrees on the intake side. The exhaust side is fixed based on the information I have seen.
By being able to adjust the valves opening and closing timing, the engine can produce max HP and TQ numbers while keeping exhaust emissions at a minimum (Tier 2, Bin 5) and provide decent mpg numbers.
DEWFPO
2007 FJ, 5AT, Sun Fusion Yellow ,
CQ, UP, GY, RB, 2Q, EL, VS.
"Enjoying the Journey"
Linear Mode
