» Tire Upgrade Garage
Old 05-07-2008, 03:17 PM   #11 (permalink)
DrSolar's Avatar
Member Number: 6011
Re: ATRAC question
The Stig previously said: View Post
Atrac is great.
I've been wondering if Atrac is better in some situations(icy, slippy) than even being fully locked?
In some cases yes. Lockers can hamper your ability to steer the vehicle in tight places and it adds a lot of stress to the drive line. ATRAC does not, but with a locker you are not steeling power from one wheel, all wheels have power all the time with a locker thus a fully locked rig is a real 4x4 with all 4 tires spinning.
I use my ATRAC only 90% of the time and the locker only comes on for short spurts and then I turn it off to avoid possibly breakage. Problem is with the IFS front end, the locker is often needed when tires lift off the ground.
As for Ice and lockers, lockers will do crap on ice, maybe make it worse. ATRAC might do you some good...maybe. Best thing for ice are tire chains or tire spikes, 4WD on ice is just having four tires spinning rather than two.
Sun Fusion FJC 4x4, AT
OE Rock Rails, OE Hitch, OE Rack
3" Skyjacker lift
TRD Wheels
285/75/16 Cepek FC-II
KC SLim Lights
Tuffy light bar with 2 Dick Cepek C-1000's
Viair Portable compressor
All-Pro Ultimate Links
2001 Dodge Dakota 5.9L Quad Cab
1987 Jeep YJ
1989 Jeep XJ
1987 S-10 Blazer
DrSolar is offline
Old 05-07-2008, 04:18 PM   #12 (permalink)
ballkillerxxx's Avatar
Member Number: 16315
Send a message via Yahoo to ballkillerxxx
Re: ATRAC question
i have it just havent had the chance to use it yet
08 BLACK DIAMOND, OFFROAD PACKAGE, CQ,
WET OKOLE SEAT COVERS
HEAD UNIT ALPINE IVA-W205. BLACKBIRD PMD-200,
REAR VIEW CAMERA
EVERYTHING ELSE ROCKFORD FOSGATE
AMPS P200-2, P-400, 1500IBD. SPEAKERS
SUB T212D2, CAPACITOR 2.5 FARAD
MORE MODS TO COME IN THE FUTURE RIGHT NOW TOO BUSY SAILING THE SEVEN SEAS WITH THE NAVY!!!!!!!
:rocket
"Damn the torpedoes, Full speed Ahead"Admiral David Glasgow Farragut (1801-1870)
ballkillerxxx is offline
Old 05-07-2008, 05:04 PM   #13 (permalink)
The Stig's Avatar
Member Number: 16839
Re: ATRAC question
DrSolar previously said: View Post
Ya thats the other advantage to atrac less broken diffs.
So is it the loss of power that means a front locker is better than atrac in hard spots? So on real smooth slippy rocks would atrac be better than lockers, like it is on ice?
08 4x4 AT, OR Package. Tires: 285/75r16 Yokohama Geolandar A/t-s.
Mods & accessories: Front hitch receiver, Smittybilt XRC8 winch, Snow Chains, $37 CB set up(works too)
Latest Vid: http://video.google.com/videoplay?do...20227075&hl=en
The Stig is offline
Old 05-08-2008, 11:16 AM   #14 (permalink)
nlk125's Avatar
Member Number: 5310
Re: ATRAC question
Basically think of ATRAC as traction control for LOW RANGE. Some situations need wheel spin, and in others you want NO SPIN. If you're in a situation where traction is marginal, and wheel spin is not desired, turn on ATRAC (or, just leave it on all the time, and turn it off when you DON'T need it). However in sand, mud or similar, you sometimes need wheelspin for floatation/tread clearing, whatever. So if you couldn't turn the traction control off to allow the wheels to spin you'd be pooched. HENCE Switchable ATRAC. The only difference between Traction control (trac) and ATRAC as I understand it, is that Traction control will apply brake to the slipping wheel, AND reduce engine power. Atrac will NOT reduce engine power. There are MANY MANY thread covering ATRAC... Try searching for more thorough discussions on the topic.
Cheers!
For those who "Get It", no explanation is necessary.
For those who don't, no explanation is possible.
nlk125 is offline
Old 05-08-2008, 12:45 PM   #15 (permalink)
The Stig's Avatar
Re: ATRAC question
Ya I know traction control pretty well. I was just wondering how good it is on the rocks, or why a front locker is better(what specific sort of situation is a locker better).
Of course it's just like any traction control except that it doesn't reduce throttle... I didn't know about that...
The Stig is offline
Old 05-08-2008, 01:34 PM   #16 (permalink)
DrSolar's Avatar
Member Number: 6011
Re: ATRAC question
The easy answer...Yes and No
Do you want both tires spinning with a 50/50 split of power in the front or do you want one tire spinning faster than the other, thus getting more traction on one side as opposed to equal on both. If one front tire is in the air ATRAC should do fine by trying to lock up the tire in the air so the tire on the ground gets traction. If both tires are on the ground and traction is poor, the locker would do better.
A locker makes the vehicle a true 4x4. Without a locker only ONE tire spins on the back and ONE on the front (i.e. gets full power). As the powered wheel slips the power is transfered by the diff to the other tire. With a locked diff both tires spin with full power at all times which equals lots of traction. This can be good and bad at the same time.
ATRAC has to slow one tire to power the other, it fools the diff into thinking that one tire is slipping more than it really is. ATRAC is an old trick used by setting the hand brake with a Posi in the rear that would make it like a mini-locker (a very poor one), same concept new package. I used to do this in my XJ and drove over everything basically with open diffs.
With ATRAC on and the rear locked you should have no issues crawling over anything with exception to very extreme stuff. Rely on your skill over the hardware and you will be better off. The real question is how do you navigate over something that is slippery without the aid of a traction device when you need one.
Did that answer it or am I way off?
3" Skyjacker lift
TRD Wheels
KC SLim Lights
1987 Jeep YJ
1989 Jeep XJ
1987 S-10 Blazer
DrSolar is offline
Old 05-08-2008, 05:06 PM   #17 (permalink)
DEWFPO's Avatar
Member Number: 7505
Re: ATRAC question
Atrac is great.
If you are on any kind of sideways slope (camber), the ATRAC will be better on icy, slippery surfaces than a locker. If both wheels per axle spin and you have very little to no traction, then gravity is going to take you down slope (not necessarily the direction you want to go). The benefit in these conditions of having one wheel per axle not spin, is that it will try to keep you from sliding sideways. You may not move forward(or backward), but you rig should stay on track in most cases.
DEWFPO
"Enjoying the Journey"
DEWFPO is offline
Old 05-08-2008, 05:12 PM   #18 (permalink)
Biatch76's Avatar
Member Number: 17118
Re: ATRAC question
I am locked front and rear and of course have the ATRAC. I have used both extensively and of course...it really depends on the situation on which is better. If you are trying to turn mid obstacle, ATRAC is very useful but I'd never trade having the option of being fully locked front and rear .
Biatch76
ARB roof rack, front bumper, front and rear lockers- PRO COMP 6inch lift, 35in Xterrain tires, wheels-WARN winch-IPF spotlights-All PRO sliders,rear bumper-SONORAN STEEL lower rear links, gearing dropped to 456, I'm forgetting stuff...what a money pit.
Biatch76 is offline
Old 05-08-2008, 06:17 PM   #19 (permalink)
FJSteveH's Avatar
Member Number: 19633
Re: ATRAC question
Thanks everyone for all of the info. I took the advice and bought an FJ today (pick-up on Saturday): 4WD, auto, rear lock diff. Per everyone's input, I did not buy the $2600 upgrade package just to get ATRAC. I'll wait until I move to Colorado in October to get the ATRAC switch because I probably will not run into many icy roads here in Florida between then and now!
FJSteveH is offline
Old 05-08-2008, 10:17 PM   #20 (permalink)
frankv64's Avatar
Member Number: 11279
Send a message via Skype™ to frankv64
Re: ATRAC question
Congrats on your new toy
07, Voodoo Blue, Auto, 4x4, Conv. Package, UG2, Rear Diff Lock, Atrac,Tow Pack.
OEM Brush Guard w/lights, OEM Roof Rack, OEM Airdam w/lights, OEM Skid Pate, OEM High Tone 2nd Horn, In Channel Vent Shades
SwissSuvs Overhead Maplights, Sliding Console Cover,Kuda Cell Phone Mount, 08 Side Visors, Viper Remote Start,PIAA Extreme White Plus Bulbs, Putco LED Dome Lights,Custom NY Mets Logos(painted on sides and back) Parrot 3200LS Bluetooth
And finally a ding on my windshield
frankv64 is online now
