Machine tightened parts can be a pain. Had that happen once when I took one of my other cars to Costco for a balance and rotation and they over torqued the lugs.
Corrosion around the hub (centric) area is the primary cause of stucked (specially steel) wheel.
A hard kick on the tire or good whack with a rubber mallet usually gets them loose.
2007 FJ Cruiser 4x4 Auto TI - Mods too long to list
2007 BMW 335i Black Sapphire - Twin Turbo
2000 Honda Odyssey EX - Navigation
1998 Toyota Sienna XLE - Supercharged
1989 Toyota Pickup - long bed
------------------------------------------ TLCA #17592
WD 40(penetrating oil) sprayed as best you can on the mounting surface where the rim meets the hub......wait five minutes and they will come off super deluxe easy.....No stress. Aluminum wheels to that all the time.....Especially Toyota and Honda for some reason.
__________________ '07 FJ, C package, 5A, Ti
mods so far
Left Foot gas pedal, Silver Star Ultras, FJ Spare Tire Cover, FJ Canvas Storage, more FJ Forum Stickers (Ti), Cruiserland Plate Frames, K&N Drop In, Vent Shades, Extremetrucktoys 2" Lift, Garmin c340, aux interior lighting, passenger armrest, 265/70/17 Toyo Open Country
I get nervous beating the wheel/tire while the truck is in the air, so I normally remove all the lugs then thread them back on about 4 or 5 turns then drive the truck back and fourth a couple of times a few feet, very slowly and softly then jack her up and they fall right off..
X2. I've used this technique a number of times on old FJ40s with "fused"-on wheels, and the slight weight of the truck will easily (and safely) break the fuse.
But, like 04e46conv said, VERY slowly and softly when lowering the jack.
AceTechno previously said:
With the lug nuts all off I would pitch the FJ into a hard corner at like 40MPH. I bet that will get them stubborn wheels off no problem.
And remember . . . . sharp left turn to get the right side wheels off, and sharp right turn to get the left side off.
I agree, regarding the anti-sieze compound. Put a thin coat of it on the hub where it meets the rim, and that helps prevent stickage. Put too much on, and it could travel up the rotor, then you'll have some real fun applying the brakes.
BTW, WD-40 should be used as a lubricant, not as penetrating oil (you'll be waiting a long time if you're using it for that). There are other products that do the job properly, such as K&W Knock 'Er Loose, or Gunk's penetrating oil product...
__________________ Dennis' Titanium 'Bird of Prey': '08 Titanium 4X4; AT; LD; A-Trac; Uniden PC78XLT CB radio & K40 hatch-mounted whip; Yaesu FT-7800R dual-band HAM radio & Comet SSB2 hatch-mounted 1/4 wave antenna Call Sign: KE5WTX; Toyota extra horn mod; no mud flaps; LT285/70/R17 Hankook Dynapro MT tars; 3" Lift (OME 884 front coils & N140S shocks, ToyTech Medium rear coils, OME N71E rear shocks); All-Phase rear diff skid; SCUBA breather mod; Steel sway bar collars; All-Pro rear shock skids and lower link skids; Digger upper and lower rear links; Rasta4x4 skids; Metal Tech step sliders; Mini-Me OEM roof rack
lol...After climbing under my old truck and beating on the alloy wheel enough that I was afraid of damaging the wheel WD 40 worked fine.....Now as far as time. I had moved the truck off the pavement in the driveway....down onto gravel. Climbed under and soaked all four wheels and hubs from behind and then wiped off what dripped off before going back onto the pavement and jacking up the first wheel.....So yeah I suppose it was 15 minutes or so.....But they all slid off without much more than a thump with my shoulder.
After that I generally smeared a bit of bearing grease around the mating surface....Never happened again in 8 years.
mods so far
